Old 04-12-2025, 11:48 PM   #1
lkt1954
Door Panel Question
I have a few questions about door panels on a 70 C!0. It has metal door panels and its been multiple years since I took it a parts. Here are my questions:
1) with metal door panels do you use upped door panel trim to help hold the panel in place?
2) what do you use to cover up the opening in the door to keep moisture and dirt from getting on the back side of the door panel?
lkt1954 is offline   Reply With Quote
Old 04-13-2025, 08:53 AM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Door Panel Question
1. Yes, the upper trim is a retainer. The metal door panel slides into it.
2. See below:
This is board member DeadheadNM 1972 Blazer
We used gaffers tape to mimic the OEM sealing on the inside of the doors as well as thick paper similar to OEM and smeared in some cosmoline.
Old 04-13-2025, 09:18 AM   #3
lkt1954
1970cts blazer- thanks.
Is the rubber molding just for a blazer or should it be on a truck door as well?
Old 04-13-2025, 09:43 AM   #4
1970cstblazer
Thumbs up Re: Door Panel Question
The original material was a white foam, so the rubber will be better than that. Trucks, Suburbans and Blazers all got them.
Old 04-13-2025, 01:23 PM   #5
HO455
HO455's Avatar
Here's a thread with some things I discovered with my door panels.
https://67-72chevytrucks.com/vboard/...d.php?t=798102
And this link goes to the most recent water prevention work I did on the Burban doors. It went all winter outside and the fabric stayed dry!
Scroll to post 1111
http://67-72chevytrucks.com/vboard/s...698377&page=45
RIP Bob Parks.
HO455 is online now   Reply With Quote
Old 04-13-2025, 04:29 PM   #6
lkt1954
HO455- thanks a lot, that really helps and clears up somethings.
Thanks again
Old 04-13-2025, 07:31 PM   #7
HO455
HO455's Avatar
You're welcome and good luck with the project.
RIP Bob Parks.
