![]() Join Date: Aug 2013
402 Rebuild
I was excited to prime the rebuilt engine for the C20 and I was adding about a quart of break-in oil when it started leaking on the floor. They only put RTV on the bottom half of the valve covers and the mating surface on both covers is deformed from them over tightening the valve covers and squishing the gasket out.
I am kind of scared to perform the break-in now, what else is wrong with the rebuild if they cannot install the valve cover gasket correctly. Forgot to mention they painted parts of the push rods and springs... It ruined a perfectly good Sunday afternoon. |
Roadtrip!
Re: 402 Rebuild
Bummer, i would be a little worried. That looks very backyardish...
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again... 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: 402 Rebuild
Part of me wants to pull it back out and remove the oil pan and heads to check everything else out.
#4 | |
Re: 402 Rebuild
https://enginetech-ca.com/ Last edited by Cali72K20; 04-13-2025 at 09:40 PM. Reason: info |
Re: 402 Rebuild
Do you have a detailed list of the work done, the parts used, and the measurements applied? Commonly called a “build sheet”.
Re: 402 Rebuild
Yes, but the machinist didn't provide and specs of work done other than it is a standard bore that was honed. I supplied most of the parts except the new pistons, bearings and valve springs.
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Re: 402 Rebuild
How thick is the sludge along the exhaust manifold side of the head? That makes me think that the heads didn't see a hot tank.
Re: 402 Rebuild
Rebuild??? Looks to me more like a re-paint... More to the point.. Those rubber valve cover gaskets are famous for doing that.. Fel Pro makes a laminated V/C gasket.. Thin metal sandwiched between two cork layers.. Expensive but does not leak and stays put very well.
Re: 402 Rebuild
^^^^Great information, thank you.
OP, The real problem is your truck is disassembled and I have a funny feeling you weren't planning on breaking the cam in, then getting it on the road the next day and spending a week or two knocking out the other 1000 miles to finish the engine break in; then after that keep the truck driven regularly/daily and put a bunch of mileage on it to make sure it's gonna run good so you can take advantage of any warranty. The issue with a lot of our trucks/people in this hobby is fellas rebuild an engine and then that engine takes 7 years to do 1000 miles for a full break in. Firstly, an engine needs to run--a prolonged drawn out break in isn't gonna be the same as one that takes a day or week. Second is simple: gotta put miles to take advantage of a warranty. I too would be scared if a shop messed up a valve cover gasket and didn't give any specs on rod clearances, cylinder-to-wall clearance, state of valve guides(material? Replaced? reamed? Knurled?), state of valve seats(replaced? are they confirmed to be hardened? Were they cut? What angles?). Heck even a sheet stating a confirmation of hot-tanking and the valve lash (if required) woulda been nice, sheesh. |
![]() ![]() Join Date: Feb 2009
Re: 402 Rebuild
You need quality gaskets (e.g. Moroso) - what a mess. Shame the guy's workmanship is poor.
after repair of the covers, and checks, seems all you can do is break it in and hope. Good information above.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#11 | |
Re: 402 Rebuild
Not sure where you came up with that assumption: "The real problem is your truck is disassembled and I have a funny feeling you weren't planning on breaking the cam in" I planned on driving it over 1500 miles one way after breaking it in cuz I'm moving out of California soon. I had planned to use it to tow my jeep. Last edited by Cali72K20; 04-13-2025 at 11:10 PM. Reason: info |
Re: 402 Rebuild
#13 |
Re: 402 Rebuild
Here are more pictures.
#14 | |
Re: 402 Rebuild
Here is the invoice I received with the work done, no measurement numbers. There is a lot of overspray on both sides of the valvetrain too. I am going to get these ordered: https://www.summitracing.com/parts/f...make/chevrolet Last edited by Cali72K20; 04-14-2025 at 12:12 AM. Reason: info |
#15 | |
Re: 402 Rebuild
"after repair of the covers, and checks, seems all you can do is break it in and hope." This is probably my best option for now, I am going to pray for the best, run it and see what happens. |
#16 | |
Re: 402 Rebuild
#17 |
Re: 402 Rebuild
I've been using the felpro silicone over steel gaskets for a few years on my Chevelle big block. Work very well and are reusable.
#18 | |
Re: 402 Rebuild
#19 |
Re: 402 Rebuild
#20 | |
Re: 402 Rebuild
Also it kinda isn't helpful that you're gonna have put on mileage on a one-way trip, unless you were intending to fully break it in while still local to the shop who did the work. Obviously getting warranty work from halfway cross country is outta the question. |
#21 | |
Re: 402 Rebuild
It's obvious, they lied about boring the block.. What else did they lie about?? |
#22 |
Re: 402 Rebuild
I would absolutely NOT start that engine!!!
Pull it out, tear it ALL down!!! |
#23 | |
Re: 402 Rebuild
Talk about overreaction ![]() "They put mustard on my burger and my coffee was too hot! SUE FOR $6.7 MILLION" edit: OP, I'm sure you are already aware of this, but any disassembly of that engine on your part more than likely voids any kind of warranty unless the builder already stated there was "no warranty". Without any build specs or receipts for parts ordered, don't get me wrong, I'd be a little suspect. But removing the engine and doing a full teardown--especially without first talking to the builder--is a financial mistake not worth making. Inform the builder of your findings and worries, and ask him if he'd be willing to give you more concrete specs or "other evidence"(???) that he actually did the work. How the builder reacts is going to tell you plenty. (do they try and extend an olive branch or do they bite off your head?) Again, I'm sorry for making such a big deal about a warranty, but if there really is anything wrong with that engine, a warranty is the only thing saving your money. And if you do anything to void that, that could be killer money down the drain. IDK how much you spent but I'd assume....over $2K? Lotta money on the line to do anything brash without first asking the builder to help fill you in on what was done, how to prove it to you, etc. Last edited by jumpsoffrock; 04-14-2025 at 07:14 PM. |
#24 | ||
All about them K’s
![]() Join Date: Jun 2014
Re: 402 Rebuild
As for towing after can break in, honestly when I used to build engines professionally I liked to see them loaded up pretty good as soon as possible to seat the rings. Idling/babying them along with little load is asking for the cylinders to glaze over, you need the heat/cylinder pressure to finish the hone and seat the rings. I didn’t like to see an abundance of rpms for the first thousand or so miles but loading them up isn’t going to hurt anything if it’s built right. I did a lot of 12 and 24 valve Cummins and I used to tell those guys once the cam is broke in to put a 8 or 10,000 lb trailer behind it and run it around for a 500 miles keeping the rpms down but dragging that load around. Never had any issues with them coming back burning oil, even after 50 or 100,000 miles.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
#25 |
Re: 402 Rebuild
Thanks for everyone's input, I'm going to call the builder and get some more info.
I ordered the Fel-Pro 1630 gaskets from O'Reilly's. |
| Bookmarks |
