Old 04-13-2025, 09:07 PM   #1
chrismoore701
chrismoore701's Avatar
Blower motor relay
I am pulling my hair out trying to figure out my blower relay on my 79. The low speeds do not work on my original. Bought a new. Low speeds work but high blows a fuse. I have bought three different and they all do the same.
The original will click when you ground pin 4. And add power to 3. But no continuity between 1 and 5. New switch continuity between 1 and 5. But as soon as you add power to 3 it sparks. A dead short. 3 relays all the same thing. See pics. What am i missing? Am i wired correct?
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 04-13-2025, 11:42 PM   #2
farmall
farmall's Avatar
Re: Blower motor relay
Have you looked at the resistor?
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 04-14-2025, 12:07 AM   #3
Dead Parrot
The relay in the pic is equipped with a suppressor diode. The arrow and line thing between 3 & 4. It is polarity sensitive. A short when +/- connected one way to 3-4, but open when connected the opposite.
By the little diagram on the relay side, 1-5 is closed when no power to 3-4 and 1-2 will be closed when 3-4 powered, while 1-5 will be open.
Don't know if the original relays came with suppressor diodes. But when computers became a thing in vehicles, suppressing voltage spikes when a relay coil is de-powered became important.
Dead Parrot is offline   Reply With Quote
Old 04-14-2025, 07:28 AM   #4
chrismoore701
I pulled the old relay apart and cleaned the points, it looks like I may be back in business
Chris
