Old 04-15-2025, 10:32 AM   #1
68isgreat
Removing door latch mechanism
I would like to remove my door latch mechanism, but the three big phillips mounting screws are burrowed in like a tick and won't budge. Have you guys found that drilling them out is the best solution?
68isgreat is offline   Reply With Quote
Old 04-15-2025, 11:22 AM   #2
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Re: Removing door latch mechanism
I would try an Impact Screw Driver First
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 04-15-2025, 12:12 PM   #3
68isgreat
Good idea, thanks.
Old 04-15-2025, 12:50 PM   #4
raggedjim
raggedjim's Avatar
If the panel is off spray some penetrating oil on the ends of the screws from the inside.
I just got done disassembling 10 doors and I managed to get all the latch mechanisms out without drilling. Make sure you are using a 4 (at least a 3) bit, the regular #2 will strip out the heads. Sometimes tightening them a bit before loosing them helps too.
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 04-15-2025, 01:07 PM   #5
Getter-Done
Getter-Done's Avatar
I use my cordless hammer drill and a #3 Phillips after letting them soak in Kroil for a few hours.
The early bird gets the worm,
85 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 04-15-2025, 01:14 PM   #6
68isgreat
Great suggestions, thanks!
Old 04-15-2025, 01:26 PM   #7
Jason Banks
Jason Banks's Avatar
That was my suggestion. Spray with Kroil or some other penetrating oil, from the back side. Roll the window down and aim....
Jason Banks is offline   Reply With Quote
Old 04-15-2025, 03:50 PM   #8
raggedjim
raggedjim's Avatar
Kroil is great, expensive, but that stuff works!
