Old 04-15-2025, 05:07 PM   #1
prateroad
Cardan joint on rear driveshaft? 71 K10
Would it be ok to install rear driveshaft with a double cardan joint? I have an old school overdrive mounted to rear of my 205 and I have a double cardan joint on one end of a shorter driveshaft. Any thoughts on this?
prateroad is offline   Reply With Quote
Old 04-15-2025, 09:45 PM   #2
LS short box
Re: Cardan joint on rear driveshaft? 71 K10
If you are thinking a double CV joint where it bolts on to the rear axle I would say no problem. My 98 Wrangler is lifted about 2-3 inches with a double CV on the rear drive shaft. 15 years no issues. I did go with 1350 u-joints.
LS short box is offline   Reply With Quote
Old 04-16-2025, 02:09 AM   #3
Richard
Not a problem at all. Just a bit more difficult to service. Had a CV shaft made for the rear of my K10 (on the front as well). CV is at trans. 8 degree working angle at ride height and hits about 17 degrees at full droop. Note that pinion angle setup is a bit different because a CV basically is at 0 degrees. The two u-joints cancel each other out. Common practice is to set pinion down 2 degrees from driveshaft angle when CV is at trans.
Richard
Old 04-16-2025, 11:59 AM   #4
68isgreat
That's a great tip. I just had a rear driveshaft made for my 68 short bed K10 and my 700r4 trans/241c output shaft angle is 4 degrees, and my pinion is angled up at 7 degrees without the bed installed or a full gas tank. I have read that those two angles should be within a degree of each other, so I was thinking of putting a 2.5 degree shim in to drop the pinion down to 5 degrees. Is that not correct? When you say driveshaft angle, are you referring to the actual angle of the driveshaft installed, or the output shaft angle of the trans? I'm a bit confused, and not sure what I should be aiming for, as this is my first time building a 4x4. I have regular 1310 u-joints installed and no lift, just stock height. Any help is appreciated. Thanks!
68isgreat is offline   Reply With Quote
Old 04-16-2025, 04:14 PM   #5
LS short box
I believe I had my Wrangler CV drive shaft done Denny's drive service? I'd call them to see what they think.
Old 04-16-2025, 04:37 PM   #6
68isgreat
Thanks. I read some more and optimum working angle is three degrees, so I think I'll shim up my transmission a tad to 3 degrees, and shim my pinion down to 3 degrees so both angles are parallel.
Old 04-17-2025, 01:40 AM   #7
Richard
Raising the transmission will increase the working angle of the u-joint. Think you are confusing component angle with working angle. Say trans is at 4 down and drive shaft at 8 down. That is a 4 degree working angle. Raise the trans to 3 down, shaft will get steeper say 9 down. You have increased working angle to 6.
Richard
Old 04-17-2025, 07:18 AM   #8
prateroad
Well my driveshaft won't fit tranny yoke cause it's for front output. I'll just have to shorten my original. thanks for the replies.
Old 04-17-2025, 01:22 PM   #9
68isgreat
How short will it be? After swapping in a 700r4/241c in my 68, the rear shaft is much shorter, only 37.5," not a whole lot longer than the front. Curious if yours is the same or similar.
Old 04-17-2025, 01:28 PM   #10
68isgreat
Great point. I can just leave my trans where it is at 4 down since it's tbi fuel injected, and put a 4 degree shim in the pinion to drop it down to say, 3 degrees to allow for upward wrap under load. If the working angles end up being more than 3-4 degrees (which seems possible considering my driveshaft is only 37.5"), I wonder if I should consider a double cardan slip yoke. I'll just have to find out when I finally get it on the road I guess. Hopefully this summer.
