Disc Brake Conversion
So today’s task was to start the Disc Brake Conversion on my truck.
Man , am I glad my son is here to help. Sure it COULD be done alone, but two makes the task MUCH easier with two knowledgeable people working on it. I’m using the CPP kit from Summit, it has MOST everything you need. (What I say next is based on me using the existing factory brake lines, and not new ones) If you use this kit, you’ll need to get adapter fitting for the flexible rake Lines in the kit, to fit the Factory lines. The fittings are 7/16-20 (male side, fits factory brake lines), and 3/8-24 female side, fits into the flexible brake lines). There’re also adapting fitting to the factory “proportioning valve”, and if y’all need those specs, I can get them. I’m going to post a couple before/after pictures as we go |
Re: Disc Brake Conversion
Looks good, thank you for the tip about the adapter!
1969 C10 Shortbed |
Or you could just use Duralast brake hose 88466 that’s what I used on my 68 worked perfectly
https://67-72chevytrucks.com/vboard/...d.php?t=818077 Grumpy is still helping with these trucks RIP The adapters for the portioning valve were real easy to find at my local NAPA
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 04-19-2025 at 10:12 AM. |
#4 | |
We have the kit 90% done. Down low, We just have to put the hoses on, and then change out the MC and Prop valve. Another update photo |
Guess they must have changed the hose in the kit. I bought CCP for my 68 last year and the hose supplied did not fit that's why I used the Duralast . Glad to hear they are listening to customers . I called their tech line and spoke with the rep and he said it had been an ongoing problem.
#7 | |
![]() Join Date: Jun 2022
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 Last edited by Rust_never_sleeps; 04-20-2025 at 03:53 PM. Reason: ends, NOT fittings |
Yes a little touch up where the hose mates to the bracket very minor .
What type of wheels do you plan to use?
Just wondering. I'm not sure all types of 6 lug factory wheels will work... |
#10 | |
I actually thought about your concern before ordering the kit, but if I’m correct, 70 and prior factory steel wheels won’t clear the Caliper, without a spacer, but 71 and later wheels will clear. All in all, the hardest part of this conversion, was getting the Ball Joints loose. Heat and Hammer are the ticket to success. Once the Ball Joints are loose, it’s a simple task, aside from getting the right brake lines for the upgraded MC and Prop Valve |
If they're 15", 4 nub steelies will fit, 3 nubs will require a spacer.
Not sure if it's a problem with 16,17" wheels
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
| Bookmarks |
