New Member
![]() Join Date: Nov 2022
1970 C20 geared too low
Hi all,
Can anyone tell me which differential this is? It has the large oval, smooth cover. Also, is there a way of changing to a higher gear ratio? Sorry--I tried rotating the photo before I uploaded it--perhaps it's too large? |
Re: 1970 C20 geared too low
Like this. 11:41
41÷11=3.727. Commonly referred to as 3.73's Or 40X13 40÷13=3.076. Commonly referred to as 3.07's or 3.08 Can you give us more information on the truck? Have you looked at the SPID on glove box door? It may specify the rear end it left the factory with. And Welcome Aboard!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 04-19-2025 at 02:16 PM. |
Looks like a Eaton ho52 rear I believe the highest gear was 3.91 my 68 has 4.57 gears . And from what I've read or heard finding a 3.91 is damn near impossible .
I believe most of the 20's had 4:11 gears except the BBC trucks
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
C20's with the H052 could get 3.54 with the BBC
C30's with H072 could get 4.10 with BBC. That's as high as they go. |
All about them K’s
![]() Join Date: Jun 2014
Pretty certain 3.54 is a dana 60 ratio not HO52.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
The Niner
![]() Join Date: Nov 2010
That is correct.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
The Niner
About 20 years ago there was an aftermarket company that made a limited supply of 3.90 gears for HO52 rears, but they're no longer in business.
New Member
Thank you all for the quick reply and great info. I will pull the cover and find out what I have.
Both of my 20s are geared low . My 72 has 4.11 with the Dana 60 and my 68 with the Eaton ho52 has 4.57 . With 31.6 inch tires it's really not to bad with the 4.11 I can maintain highway speeds with no problem the 4.57 with th 6 banger is reving pretty good at 60mph but it's still doable. Much different than what my Chevelle was like with the 4.11 gears and smaller diameter tires I changed them out to 3.54s .
My 85 K20 has 3.23 gears and a 700r4 . That truck will cruise at 80-85 all day . Takes a bit to get to speed though
The Niner
Pretty sure all C/20 big blocks (after 1970 anyways) came with 3.54 gears.
#13 |
What a shame. Must have been poor marketing at the time, a lot of C 20's could have used the upgrade. I surely would have purchased them if I would have known about them. Never seen them advertised. Most '48-'68's 3/4 tons are 4.57 HO52's, '69-'72 I would say 50/50 4.11-4.57 for trucks that came with a H052. A 3.70 ring gear set would have been cool too, but probably never done.
#14 |
![]() Join Date: Jul 2021
My 72 C20 Cheyenne Super had factory a 3.54 posi unit. But I changed it out due to the clutches burning up. I changed it out for a Yukon 4.10 and a locker. My 32" tires and Gear Vendors overdrive unit allows me to cruise at a nice 70 mph on the highway with no problems.
Darrell ![]() 1972 Cheyenne Super C20 (Heavenly Too) (My Street Truck) 2000 S10 Xtreme (Black Magic) (My Drag Truck) |
#15 | |
#16 |
The Niner
That is correct.
#17 |
![]() Join Date: Feb 2022
If you have a manual transmission, change away. If you have an automatic transmission, caution needs to be taken so as not to gear out of your stall speed range of the torque converter. Going to a lower numbered rear can put up you in a range that keeps you in the stall range while driving in town. As I found recently, this will cause the converter to run on the hot side of things. If you only monitor the tranny pan with a gauge, you will miss the hot converter because our radiators do pretty good at cooling tranny fluid.
#18 |
![]() ![]() Join Date: Jul 2003
My 1972 402 Cheyenne Super 20 has an Eaton rear with 4.10 ratio as per the SPID.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
#19 |
With the proliferation of overdrive transmission, it is common these days to change the transmission, not the differential ratio.
Almost impossible to reduce the motor rpm by 30% by changing the differential ratio. Easy with the overdrive. Highway rpm drops from 3000 to 2000. By changing the transmission, you retain the low-end grunt and pulling power and significantly reduce interior noise. The newer 8 and 10-speed transmissions often have three overdrive ratios. |
#20 |
More than likely you have 4.57 gears in that Eaton, as the 4.11's are harder to find. That's gonna make it harder to get highway cruising, but swapping the transmission is the easy choice if you want to leave the Eaton. The truck will be much cooler with that rear end, but make sure you know what you're getting into with brake, bearing, seal components. They are not prone to fail, just hard to find.
1970 C/2500 Ol' Green https://67-72chevytrucks.com/vboard/...d.php?t=6680032016 GMC Sierra K1500 1953 Mercury 2 Door Sedan https://67-72chevytrucks.com/vboard/...17#post9381817 |
#21 |
I found this 10 year old thread that talks about the Eaton HO52 gears. https://67-72chevytrucks.com/vboard/...d.php?t=625981 It mentions the very, very limited production of "Randy's R&P 3.90 gear sets". That thread is a good read and offers some additional info.
My '67 already has a Dana 60 so a switch from 4.57 to 3.54 was relatively easy and junk yard cheap for a Dodge carrier and gears. The difference between Dodge and GM Dana is the yoke. Hoopers Gear in Sun Valley, CA mentioned in that thread, had a yoke to make the switch. Most people seem to prefer to switch to an OD transmission. I have considered a 5 sp manual, but only because the 3 to 4 spread is high when towing on a hill with the sm465 and 3.54 gears. When not towing the 292 enjoys it just fine. Don't need OD with 3.54 gears, at least for my truck.
'67 GMC 2500, 292, 4spd, AC |
#22 |
Water under the bridge, but the real problem was GM, or the other big 3 auto manufactures. There should have been a 5 speed overdrive manual transmission offered in 3/4 tons and 1 tons back in the day. They only offered light duty 3 speed overdrives that weren't designed for heavier vehicles. International did offer a 5 speed overdrive boxes in their pickups. This would have been a complete bolt in, just a shorter driveshaft would have been necessary and speedo would have threaded right in, no electronic B.S. The .8 5th gear in the'69 Chevy C50-60 brochure charts is just right for a heavier vehicle. The .7 5th gear, that is common in most modern overdrives is, IMO, too high of a reduction in rpm. The bottom chart, the CH 465 and New Process offerings didn't help, 1:1 final drives.
#23 |
The Older Generation
If you have an SM465 4 speed just do this. https://www.67-72chevytrucks.com/vbo...d.php?t=673588 You can do it to replace an SM460 too but you have to use the SM465 bell housing. That way you still have your low 1st gear but also overdrive. .
#24 |
New Member
Thank you all for the great ideas. I was looking at the price of the NV4500's and I think I am going to go with larger wheels. I saw where 72c20customcamper has 31.6 inch tires on his C20. Will that make a noticeable difference? have 8 lug steel wheels on it now. I don't have the truck here now and I don't remember the tire size. They are Bridgestone Commercial. Also, I just rebuilt the SM 465 and it works flawlessly so I'm not ready to give up on it yet.
#25 | |
The Niner
| Bookmarks |
