Old 04-20-2025, 02:13 PM   #1
68C101775
Wilwood rear disk help
Good afternoon all,
I have a built 12 bolt with a wilwood rear disk brake kit. When I went to install the calipers aren’t lining up with the rotors. They are offset too far inward toward the housing. This creates the issue where the only way I can shim it will make the problem worse. I’ll attach a pic for reference.
Any tips are appreciated!
68C101775 is offline   Reply With Quote
Old 04-20-2025, 02:40 PM   #2
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: Wilwood rear disk help
rotated
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 04-20-2025, 04:08 PM   #3
LS short box
Stock axles? Disc fully seated on the axle?
LS short box is offline   Reply With Quote
Old 04-20-2025, 04:26 PM   #4
68C101775
Aftermarket axles, not sure of the specifics because I bought the axle already built. I pulled them to install the parking brake/disk brake bracket and they’re nice and beefy but no brand or anything on them. The calipers are fully seated on the axle flange face.
Old 04-20-2025, 04:46 PM   #5
weq92f
weq92f's Avatar
I did a quick Online search. Found a discussion regarding wilwood kit for rear brakes on some other platform but, in it they discussed the kit was engineered to work with 2 different "offsets" or axles. Simply swapping the mounting brackets from side to side (and flipping them over as a result) was the method of switching between the 2 specs.
Another discussion had the installer grinding down the mounting bosses to move the caliper where needed and yet another discussion had the installer shimming the rotor out slightly with a spacer.
In one instance, the installer found the caliper itself was out of spec and had wilwood send him a new one. He found this by comparing the two calipers with detailed and precise measurements.
Not sure any of that applies in your case.
Hth,
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 04-20-2025, 08:10 PM   #6
68C101775
Sweet thanks for that. I’ll try flipping sides to see if that’ll work, I don’t know if it will with how the parking brake cable is routed, past that I’ll either have to grind or run it.
Old 04-21-2025, 01:01 AM   #7
Rick Bollinger
I had the same issue with my CPP set up. I had a machinist buddy takeoff I believe .030 off of the mounting brackets. I am wondering if the mounting jigs at GM wasn't getting a little worn when they welded the ends on the axle tube. Both sides were the same on mine.
Rick Bollinger is offline   Reply With Quote
Old 04-21-2025, 07:32 AM   #8
68C101775
Gotcha, both sides are the same on mine as well.
