Old 01-16-2004, 06:48 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
DIN size hole for radio?
What is the size hole needed to mount a DIN sized radio in the dash?
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 01-16-2004, 07:09 PM   #2
MMGOODIE
I love doing it topless
MMGOODIE's Avatar
I am not sure what the "size" is but we use single din radios. double din are for like the big radios that just about all of the auto companies are using now.
Single DIN
Mikey
"If you can read this, thank a teacher;
If you are reading it in English, thank a soldier."
MMGOODIE is offline   Reply With Quote
Old 01-16-2004, 07:10 PM   #3
MMGOODIE
MMGOODIE's Avatar
Double DIN
Hope this answers your question.
Mikey
Old 01-16-2004, 07:25 PM   #4
cheatham
I need a brake!
cheatham's Avatar
Someone will correct me if I am wrong but I believe the standard size is 1 1/2 DIN.
JP
MEMBER OF THE DISCS UP FRONT CLUB
1971 Chevy C10
cheatham is offline   Reply With Quote
Old 01-16-2004, 07:30 PM   #5
mocwon
Keep On Truckin'
mocwon's Avatar
I am looking for the "single" DIN hole size. I think it is 2" X 7" but need to confirm before I slice into the dash.
Just Passin' Thru
Old 01-16-2004, 07:33 PM   #6
cheatham
I need a brake!
cheatham's Avatar
I never knew this:
DIN- Acronym for Deutsche Industrie Norm (Deutsches Institut fuer Normung), the German standardization body. A world reference standard for the mounting parameters of many common receivers ( Head ends) as well as other types of cables and equipment
The standard DIN size head unit opening is approximately 7" wide x 2" tall.
Apparently it is called simply "DIN"
JP
1971 Chevy C10
Old 01-16-2004, 08:21 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I wouldn't cut anything untill you have the new stereo in your hands.
Then take the mounting cage and trace around it, and cut on the inside of your markings.
Old 01-16-2004, 08:35 PM   #8
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
I have a single din Alpine mount in my hand here, it measures:
2-1/16 OD x 7-1/8 OD
actually maybe a 32nd larger than this all the way around.
"Who owns this car with the peace sign, the mag wheels, and four on the floor?"
67 Short Step
283/TH400/4.11
BtnkBndt is offline   Reply With Quote
