Old 05-01-2025, 11:53 AM   #1
Mains52
Leaf springs where is everyone putting them?
Folks,
Since I smashed most of my triangulated 4 link in my crash. I am installing a leaf spring set up. I currently am thinking under the frame, but I've seen some of you go inside or outside of the frame. Just wanting to see different set ups.
Mains52 is offline   Reply With Quote
Old 05-01-2025, 03:47 PM   #2
nvrdone
Re: Leaf springs where is everyone putting them?
what vehicle is this on? do you want to go with a stock location & springs or some other set up?
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's
Bought in 1973 for $235.00. Had it longer than my wife & Kids!!
nvrdone is offline   Reply With Quote
Old 05-01-2025, 04:44 PM   #3
Mains52
52 chevy 3100 stock ish location but I no longer have the stock mounting brackets
Old 05-01-2025, 08:56 PM   #4
nvrdone
A quick internet search shows Chassis Enginering has a mount kit & springs. Springs mount under the chassis.
There are also kits available to mount S10 springs.
I would stay with springs mounted under the chassis. Mounting them outboard reduces how wide a tire you can install. Mounting them inside would require boxing the frame.
Old 05-01-2025, 10:03 PM   #5
caseyjones
I set mine under the frame. I used 3" lowered leaf springs for a Ranger and I mounted the top of the shackle up in the frame to get it low without blocks. Haven't driven it yet so don't know what the ride is like.
caseyjones is offline   Reply With Quote
Old 05-02-2025, 11:21 AM   #6
JDarby
JDarby's Avatar
Too bad you are not closer to me, I have the pair
I took off my truck (which were re-sprung) that you
could have for the taking with the front spring bracket's
included.
1955.1 GMC 100 RestOMod
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
JDarby is offline   Reply With Quote
Old 05-02-2025, 05:33 PM   #7
mr48chev
mr48chev's Avatar
I've been eyeballing a little Dodge mini ram van that I have out here that is a storage shed with wheels but those Mopar mini vans have rear leaf springs and brackets that all unbolt from the van and former research says that they come in two lengths depending on if it is a Caravan or grand caravan.
We had a thread on it several years ago.
My ongoing truck projects:
