Old 05-05-2025, 02:58 PM   #1
8man
Radiator
I have 1200 miles on the 48, and I just found a small leak in the radiator where a bolt rubbed it. I can fix the bolt, but what are your recommendations for the radiator?
Thanks.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 05-05-2025, 04:13 PM   #2
mr48chev
mr48chev's Avatar
Re: Radiator
S-10 Chassis pretty well puts the skizzle on any viable suggestions as they all seem to be set up differently. Plus I haven't seen our resident S-10 swap guru on here for months.
I just bought a KKS 3 row GMC style radiator that moves the core forward an inch or more
Bay item number:225850522950 for my 48 to get room for the 292. I may have to modify the crossbar on top of the stock core support or use spacers to get the tank to clear but still gain room but haven't got to that yet.
My ongoing truck projects:
Old 05-05-2025, 04:41 PM   #3
JDarby
JDarby's Avatar
Re: Radiator
I have a stock 55 GMC radiator that holds fluid, not sure what the S-10 set up looks like
but I thought I'd throw that out there since we both live in Tejas!
1955.1 GMC 100 RestOMod
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
JDarby is offline   Reply With Quote
Old 05-05-2025, 04:43 PM   #4
8man
Re: Radiator
Thanks guys.
I was wondering if the aluminum radiator can be repaired, or if I have to replace it.
I will be pulling the radiator, and I have to check, but I think a 48-55 radiator might fit. It'll be next week before I can tear into it.
8man-aka Robert
Old 05-05-2025, 04:58 PM   #5
leegreen
Re: Radiator
It it is just a hole in one of the tanks there is a reasonable chance someone can tig it up for you
leegreen is offline   Reply With Quote
Old 05-06-2025, 08:02 AM   #6
8man
Re: Radiator
Thanks, but it's not in the tank, the bolt went in between a couple of the fins.
8man-aka Robert
Old 05-06-2025, 09:23 AM   #7
1project2many
Re: Radiator
In the early days of plastic / aluminum radiators we would use plastic weld to patch very small holes in the tubes. In the days of copper / aluminum if the tube couldn't be soldered the tanks would be removed and the ends of the tube soldered shut. Now it seems like the common answer is to throw it out if it's broken.
1project2many is offline   Reply With Quote
Old 05-06-2025, 09:27 AM   #8
8man
Re: Radiator
Thank you, that is what I was thinking. I was hoping but thinking it. When I get it out, I'll know.
8man-aka Robert
Old 05-06-2025, 05:14 PM   #9
mr48chev
mr48chev's Avatar
Re: Radiator
We used to have 20 radiator shops within 30 miles of my house and now there is one and the next closest real radiator shop is 68.8 miles away.
I have lost track of how many aluminum and plastic radiators I have scrapped in the past 20 years with the issues with the plastic. Always a plastic failure but at least they are cheap.
