Old 05-06-2025, 06:58 AM   #1
elorenzof
Parking Lights stay on
Good morning everyone,
I have a 1970 C10, newly restored from the frame up. Putting on the final touches and little things that need to be completed.
I have an issue that i hope you all can help. I have used new M&H wiring harness(s) for the entire truck. Dash Harness, Engine Harness, Front Harness, Intermediate Harness to rear, and finally rear harness is all new from M&H. Also, have all brand new switching, headlight switch, Ignition Switch, brake light switch, etc... Everything is relatively "Plug and play"
My issue is that my parking lamps stay on at all times. Key on, or key off, ( i know its a different circuit) I have to disconnect the battery to get them to turn off. I thought it was an internal headlight switch problem, and i changed out the new headlight switch. We all know nothing is made like it used to be.
When i put the new headlight switch it was still hanging out of the hole in the dash and i tried it by pushing in the switch all the way in to have everything off and it worked! Parking lights went off. Pull the switch out one click, parking lights come on. Pull out two clicks, headlights / parking lights all work.
However, after i mounted the switch in the dash it appears it grounds thru the dash and now the parking lamps front, rear, side markers etc, stay on. so im back to what it was doing.
Can anyone shed some help i would greatly appreciate it.
Lorenzo
elorenzof is offline   Reply With Quote
parking lights, switch
