Hi beams work low beams don't
I am trying to figure out why my LED low beams are not working. This is what I know:
-Dimmer switch does read 12v on both hi and low legs -No voltage at headlight connector for the low beams. 12v on the high side leg -Using a 28 circuit Painless Wiring Harness Does anyone have an idea if there is a connector between the dimmer and headlight connector? Besides the fuse block. -Tail lights do not come on when parking or headlights activated (But I think that might be a separate issue) -Front parking lights come on -Turn signals work properly
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
| Bookmarks |
