Old 01-16-2004, 11:29 PM   #1
72SWB4X4
Florida Key's Member
72SWB4X4's Avatar
cubic inch formula
what is the formula for figuring out cubic inches
i just called the machinist that rebuilt my BB
4.250 bore + .060
4.125 stroke
it was the same cost to stroke my stock steel crank as have it turned and one journal welded
CUBIC INCHES WON
Craig Wood
1972 SWB Chevy Cheyenne 4X4
Restored stock except 454 (481 cu. in. now)
most options Available
pictures of my truck http://myoldtruck.com/gallery/browse...500&userid=528
Come to florida and visit www.Paradisewatersports.com
72SWB4X4 is offline   Reply With Quote
Old 01-16-2004, 11:47 PM   #2
Perchjerker
Beer Power!!!!!!!!!!
Perchjerker's Avatar
Is that a lwb to swb conversion?
Rather be fishin'
Perchjerker is offline   Reply With Quote
Old 01-16-2004, 11:53 PM   #3
kwmech
PI times radius squared times stroke.
Old 01-16-2004, 11:55 PM   #4
72SWB4X4
72SWB4X4's Avatar
no not a long bed conversion
Craig Wood
Old 01-17-2004, 12:01 AM   #5
jmanz69
Careful, they attack...
jmanz69's Avatar
481 cubic inches.
It's 3.14 X radius (2.155) squared = 14.582
This is the area of the circle. To get the volume of the cylinder, you take that number and muliply it by the stroke (4.125). This gives you 60.152. This is how many cubic inches each cylinder is. Then just multiply by the number of cylinders in your engine (8).
And you get the magic number 481.214 cubic inches. That's a big engine. Hope it helps.
jmanz69 is offline   Reply With Quote
Old 01-17-2004, 12:02 AM   #6
Sweet72
Sweet72's Avatar
Pi X r2 X depth X number of cylinders... 3.14 X 2.125 X 2.125 X 4.125 X 8 = 467.90906 ci. Hope my math is correct, but this is the formula.
-Sam
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-17-2004, 12:06 AM   #7
jmanz69
jmanz69's Avatar
sweet72 you forgot to add the .060 for the overbore. That adds up when you do the volume.
Old 01-17-2004, 12:10 AM   #8
demi
demi's Avatar
Yep, 481.45908
bore x bore x stroke x 0.7854 x # cylinders.
demi is offline   Reply With Quote
Old 01-17-2004, 12:13 AM   #9
72SWB4X4
72SWB4X4's Avatar
JESUS
this thing really grew
I guess that is why the gas milage is not any better than before
Craig Wood
Old 01-17-2004, 12:19 AM   #10
Sweet72
Sweet72's Avatar
Yep, sorry fellas. forgot the .060 over...
_Sam
