01-17-2004, 12:00 AM | #1 |
What's DIRECTLY under the drivers feet?
I've been getting a WEIRD squeak/rattle, that's coming DIRECTLY from where my feet sit at (on the drivers side of the tranny hump). What's exactly under there that could be loose or broken? Just the tranny crossmember, and cab mounts right? I've checked all those, they're perfectly tight...
01-17-2004, 12:08 AM | #2 |
Robert Olson Transport
could it be exhaust or the catalyctic cover?they squeak and rattle or the u joint but thats more of squeak only
01-17-2004, 12:33 AM | #3 |
What's under the drivers feet...........the floorboard of course.........couldn't resist.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
01-17-2004, 12:56 AM | #4 | |
01-17-2004, 02:16 AM | #5 | |
Waaaay to go!! |
01-17-2004, 10:19 AM | #6 |
Mine does something similar, it feels like its something knocking on the floorboard at my feet. I didnt change any floorboards. In fact my PATROL CAR does the same thing (CROWN VIC)
2004 Silverado Crewcab (Dark Spiral Gray) |
01-17-2004, 12:38 PM | #7 |
On my truck, the shift linkage is under there.
Steve 86 K30 4x4 6.2L Diesel\TH400\NP208 - 14bolt FF rear w/detroit locker and Dana60 front w/detroit locker- both with 4.56 gears "Runs on Mud" |
01-17-2004, 12:58 PM | #8 | |
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
01-18-2004, 12:28 AM | #9 |
I have something that rolls around under mine? Can't figure it out.
01-19-2004, 03:44 PM | #10 | |
You know what, now that I think about it even more I dont think its made that sound since my door spring broke. The pins are no good, I really need to fix it. Well I opened the door getting gas one day and the spring snapped and half fell on the ground. Maybe it was the door pin doing it and the popping traveled into the floor pan. Now that the spring is not there, maybe it doesnt do it. Ill check in 10 minutes at lunch and see if the sound is gone. EDIT: Well my truck no longer does it. It must have something to do with the door pins and the spring. I noticed the popping sound around the same time I noticed the door sagging. I have been slacking and left the door sagging for awhile now. The sping (Z-shaped at hinge) broke and fell off. Not popped since the spring broke. Maybe check your door and see if it sags at all. Open the door a little bit and lift with the handle.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * Last edited by PHOENIX; 01-26-2004 at 04:24 PM. |
01-26-2004, 02:12 AM | #11 | |
01-26-2004, 02:23 AM | #12 |
i would venture to say that's the closest thing that is a part of the vehicle. however, if you want to get technical, it would probably be a shoe, or a sock or some sort. unless of course you're driving barefoot, which i think is illegal in some states. anybody know for sure?
01-26-2004, 03:16 AM | #13 |
he said under the feet not around them.
Semper Fi seafoam green 79 K10 stepside with a 6" lift, 33" baja claws, billet interior, autometer gauges, 350/t350 |
01-26-2004, 03:45 AM | #14 |
wow, hasnt even been here a month, and he's already a post whore. wont be long and you'll have an avatar.
01-26-2004, 04:51 AM | #15 |
Heat shield for the catalyst? Crawl under & hit it with your fist. Sound familiar?
01-26-2004, 11:16 PM | #16 |
BANNED
I'd also check the shock absorber bolt hole on the frame. If its damaged, you can feel it at your feet.
