Old 05-25-2025, 07:44 PM   #1
michael bustamante
michael bustamante's Avatar
Need some water pump help guys
So my 67 GMC, has an aftermarket, A c compressor it is a york and it mounts on the front driver's side of the 350 engine. Alternator on the passenger side. I am trying to put a fan clutch on the truck as it does not have one currently and use this two extensions to get it close to the radiator. I tried mounting the a fan to the water pump using the studs, and it is not going to wor. It will hit the york a c compressor. I'm really thinking a long water pump will work to clear the York AC. Compressor but I cannot find one on Amazon. Do any of you have a part number? I could use? Also, does a long water pump mount the same?
1967custom
michael bustamante is offline   Reply With Quote
Old 05-25-2025, 08:50 PM   #2
tim_mc
tim_mc's Avatar
Re: Need some water pump help guys
Hi Michael, Is there a way to move the compressor further away from the fan and run a longer fan belt?
Also, is your '67 an original V8 truck? If not and the 350 is mounted in the rearward position like I6 & 4x4 SBCs, you might want to consider the deeper 4x4 shroud, which is what I did on my '67 that had an original straight 6. I'm using a short water pump and no spacers with my Derale 18" fan (17118) and Hayden 2705 clutch. That's a 4x4 upper radiator hose in the pic.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 05-26-2025, 05:49 PM   #3
Rick Bollinger
I believe if you put on a long water pump you will also have to change out all of your pullies and brackets. Things get real frustrating at that point. Maybe someone will chime in about that.
Rick Bollinger is offline   Reply With Quote
Old 05-26-2025, 05:58 PM   #4
Rick Bollinger
You may also consider Tim mc set up. It looks exactly like mine which opens everything up. Makes maintenance a whole lot easier
Old 05-26-2025, 06:03 PM   #5
Rick Bollinger
Sorry for the first picture uploaded the wrong one.
Old 05-28-2025, 02:57 PM   #6
MARKDTN
OP-are you sure you don't already have a long pump? That alternator bracket is '69 up car and would be for a long pump. I would start over and dump that aftermarket York compressor and go with a Sanden.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-28-2025, 04:00 PM   #7
kwmech
^^^ This. Existing bracketry indicates long pump already
Old 05-28-2025, 04:27 PM   #8
Louisvillekytruck
It has a long waterpump on it now
Louisvillekytruck is offline   Reply With Quote
Old 05-28-2025, 07:23 PM   #9
72c20customcamper
72c20customcamper's Avatar
Definitely a long water pump by the placement and bracket for the alternator like on my 72 that I’m currently working on putting it back to a short as the fan is to far into the shroud . If you put a clutch fan on the fan will definitely clear the compressor as it will be deep inside the shroud . Not ideal for cooling though.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 05-28-2025, 08:11 PM   #10
Rust_never_sleeps
Rust_never_sleeps's Avatar
Interesting. I know there are variations in layout, but hadn’t seen AC on the driver’s side. I’ve never seen a sidewinder compressor like that either.
Nobody asked, but here’s what I’m familiar with. Shoestring is aftermarket, or perhaps a dealer option
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 05-29-2025, 10:09 PM   #11
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
What is a "shoestring"? Just curious. This York setup was a very common installation, back in the early '70s. We'd find a new car for a customer equipped mostly like they wanted, but it wouldn't necessarily have AC. They went to a trusted shop for aftermarket AC to be installed.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 05-31-2025, 12:16 AM   #12
Rust_never_sleeps
Mine came with an aftermarket cable management option, you can see it hanging from the vacuum ball ;-)
Old 05-31-2025, 11:48 AM   #13
Steeveedee
Steeveedee's Avatar
OK, you got me!
~Steven
Simi Valley, CA
