Quadrajet Rear Choke Pull Off Question
I’m in the process of relocating/replacing some vacuum lines. The rear choke pull off on my Quadrajet has two lines coming out of it - one small vacuum line hooked up to a vacuum port in the back base of my carburetor and a bigger line that runs into the PCV valve on the driver’s side valve cover. I’m wanting to run a line from that PCV to the bigger port on the front of the carb but am not sure what to do with the bigger line coming off of the back of the choke pull off. I can’t find any information on this and I’m at a loss. What should I do with that other line? Does that also need a vacuum source or is it some type of breather? Thank you in advance for any help. This is the best photo I currently have but I can’t find any take some better photos when I get home if needed.
70 GMC 1500 Sierra - Original paint, mostly original 350 and TH350 86 Honda ATC200X Three Wheeler 10 Dodge Ram 1500 |
Re: Quadrajet Rear Choke Pull Off Question
This question begs to be asked.. Why do you feel the need to "redesign" vacuum hose routing?? That choke pull performs more than one function.. Disrupting those functions could introduce problems that didn't exist prior to the changes. In other words -- "If it ain't broke, don't fix it"...
#3 | |
I also ran a line to my air cleaner to operate the flap in it, kind of going for a more factory correct look overall. I just couldn’t figure out why that rear choke pull off needed two vacuum lines and am stumped.
#4 | |
#5 | |
I've never seen the hose for a pcv valve get it's vacuum source from a choke pull, never.. What I have seen is some aftermarket vacuum pulls having a travel adjustment on the back side. I've not seen many of these, only a very few.. Are you sure that large "port" actually applies vacuum to the pcv hose?? Start the engine and check for vacuum at the pcv valve itself..
#7 | |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Looks like a stock carb converted to integral electric choke. I see holes where the choke pull off would go if it were the standard (factory) divorced choke. Or am I missing something? And for sure that PCV hose should be connected to the port on the front, with nothing else tapped into it. The carburetor is calibrated for that flow.
ETA: The integral choke uses a piston inside the housing for choke pull off, right? if it is an aftermarket piece, maybe not. But that choke uses the port that goes to the air cleaner heat flap. What is the number on the carb?
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; 05-28-2025 at 03:37 PM. |
#9 | |
What year is the truck and/or engine? I'm a Q-jet guy, but that doesn't look like a 60's or 70's style. All the earlier style Q-jets I've ever seen or worked on had the choke pull-off where the 2 holes are at the front of yours. And the electric choke looks to be an add-on.
That is not a vacuum port. There is an adjustment screw in there it should have an allen head screw The small line is the vacuum supply to the choke pull off. The way it is hooked up it is just plugging the big line
#12 | |
https://cliffshighperformance.com ETA- really try to get your original carb back. That looks like a later smog carburetor that can't possibly have the right calibration characteristics for your truck.
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; 05-28-2025 at 08:12 PM. |
#13 |
![]() Join Date: Jun 2022
FTR, there are ‘letric choke conversions for divorced chokes. They’re clunky to look at, but not sure I’d just swap a carp to get
Mike’s Carburetors has pretty good tehc doc’s and I like how he lays out information better than Cliff’s book. I’ve gotten a few skull-imploding answers from Cliff’s q-jet forum, but there are mostly very knowledgable folks on there and Cliff himself still chimes in. Definitely an interesting enough variation to elicit some response
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
#14 |
I have an electric choke from Mike's, myself. Easy to install, and it works great. BUT, the OP's mechanic replaced the entire carb and did strange (to me) stuff on it...and it's not working properly for him. There are carb experts out there other than Cliff. I've had good luck with his parts and advice. I know other people who swear by different rebuilders. Everyday Performance is another rebuilder I've seen excellent results from, when it comes to carburetors, and he also does some great restoration plating.
#15 | |||||
I really appreciate all of the help!
I'll have to check them out. Quote:
#16 | |
Just because there’s a couple extra holes in the carb body doesn’t mean something is missing. Here’s a carb with only a rear pull off. https://www.amazon.ca/NENKUTEN-Carbu.../dp/B09BZ1VCBM |
#17 | |
#18 |
Seen this the other day from the older Qjets...
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
#19 |
For the purpose of this post, I'll use the term "vacuum powered device".. Some of those Q-Jets had the choke pull mounted on the front, and a second "vacuum powered device" on the rear. When equipped with 2 of these devices, the one on the rear functioned as a secondary air valve (the big "flapper valve" on top of the secondaries) inhibit.. These Q-Jets were equipped with a divorced choke. Until the choke control spring reached maximum temperature, a small "L" shaped bar was held in contact with the secondary throttle plates, prevented them from opening. The vacuum supply to that rear "vacuum powered device passed through a temperature sensor switch. When this switch opened, vacuum was applied to the rear "vacuum powered device". The arm retraced and "freed up" the secondary air valve..
In later years, The temperature switch was eliminated and the rear "vacuum powered device" performed dual duties -- Choke pull AND secondary air valve inhibit.. This one operated 2 rods.. The rod going to the choke lever had a "horseshoe bend" in it... Opening and/or closing this bend was/is how the amount of "pull" is applied to the choke lever. |
#20 |
Do better research.
Like this for vacuum diagrams. https://www.google.ca/search?q=vacuu...dj&sclient=img |
#21 | |
I reached out to Cliff, as rust_never_sleeps recommended, and he confirmed that the shop screwed up running a line to that.
#22 | |
#23 |
If it runs and drives well, they probably didn’t do anything stupid with jets/rods, which is common when people just slap on a q-jet from a rando donor vehicle, so nice to have avoided that cowpie
Also, carb they gave you does have APT, so maybe that’s an upgrade over what you had, but you probably need to strip it down and build back the way Mr Rochester intended
#24 |
As I often say, this guy’s work illustrates the difference between clever and smart
#25 |
| Bookmarks |
