Old 05-28-2025, 03:34 PM   #1
May70
May70's Avatar
Anyone hide/reroute windshield washer hoses?
Hey searched a bit for pics of how anyone has hidden or rerouted their wiper hoses. Only found two on previous gen trucks.
Trying to clean up the firewall where reasonable. I’m debating on these hoses. I don’t like where they come out
Anyone got some pics?
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 05-28-2025, 08:15 PM   #2
tim_mc
tim_mc's Avatar
Re: Anyone hide/reroute windshield washer hoses?
Changing to an '88-'93 S-10 washer reservoir with integrated pump (GM1288137) eliminated washer fluid hoses through the firewall. It cleaned it up a bit. I used one of the holes to route the washer pump power leads. The hose and wiring could be routed inside the fender to hide more of the connections. I kept them accessible, so they're wrapped with the hood lock and brake switch lead.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 05-29-2025, 11:48 AM   #3
68isgreat
That's a clean installation. Any issues bypassing the oem pump?
68isgreat is offline   Reply With Quote
Old 05-29-2025, 12:03 PM   #4
67C10Step
67C10Step's Avatar
I did the same conversion as tim_mc but chose to run the wiring and hoses around through the fender. Used one of the holes in the washer hose grommet as the pass through for the wiring harness.
I don't think the squirters ever worked this good with the old pump, even though I really don't use it much.
1967 C10
1997 Ford Ranger
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 05-29-2025, 12:36 PM   #5
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I used the S10 bottle and pump as well. I also used the S10 coolant recovery bottle as well.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 05-29-2025, 01:21 PM   #6
pjmoreland
pjmoreland's Avatar
I copied you with the S-10 tank on my '71 K/10. The sprayers are quite powerful now. I routed the wiring through the bulkhead connector. You can see the yellow and blue wires in the photo.
pjmoreland is offline   Reply With Quote
Old 05-29-2025, 01:49 PM   #7
dagnabbitt
dagnabbitt's Avatar
10 years on this site and I'm still getting great ideas from you guys. One more thing to look for on my next junkyard crawl, or just buy one new.
https://www.amazon.ca/DNA-OEM-WT-GM1.../dp/B09MFJPFZQ
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 05-29-2025, 02:29 PM   #8
68isgreat
There must be lots of other makes/models of reservoirs with internal pumps that would work well also I should think.
Old 05-29-2025, 02:40 PM   #9
May70
May70's Avatar
Do you have a picture of the hose routing?
Old 05-30-2025, 09:53 PM   #10
zicc1835
zicc1835's Avatar
I cleaned mine up like this .....and pray for no rain ......LOL
zicc1835 is offline   Reply With Quote
Old 05-31-2025, 09:31 AM   #11
Lee H
Lee H's Avatar
Full size chevy truck
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have all original numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 05-31-2025, 10:26 AM   #12
tim_mc
tim_mc's Avatar
Thanks - No issues - it works a lot better than the OEM setup. I removed the OEM washer pump in the cab and just extended the blue & white leads to the new pump under the hood.
Old 05-31-2025, 10:43 AM   #13
70STOVEBOLT
70STOVEBOLT's Avatar
Why would you want the squirters without the wipers?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-31-2025, 12:39 PM   #14
Ol Blue K20
I believe that's called humor.
Dale
Old 05-31-2025, 07:39 PM   #15
zicc1835
zicc1835's Avatar
that was meant to be humor
Old 05-31-2025, 08:02 PM   #16
70STOVEBOLT
Phew! I was hoping that it was humor.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 06-03-2025, 12:26 PM   #17
mkmc69
mkmc69's Avatar
That looks clean. I like it.
mkmc69 is offline   Reply With Quote
Old 06-06-2025, 11:07 AM   #18
raggedjim
raggedjim's Avatar
metaldoc rerouted his and used these bulkhead pass-throughs...
https://67-72chevytrucks.com/vboard/...&postcount=188
raggedjim is offline   Reply With Quote
Old 06-06-2025, 08:14 PM   #19
chewychevy67
I added a 1975 vette pump to the bottom of my original bottle and ran the hose from It thru the cowl and the hoses run on the inside of the cowl. With it all together you never even know it's been altered except you can't see the hoses in the gutter at the firewall anymore.
chewychevy67 is offline   Reply With Quote
