Old 06-02-2025, 10:49 AM   #1
Backpayne
Hydroboost without power steering?
Howdy!
I'm interested in running a hydroboost system in my '64 due to low vacuum from a wild cam. The only problems is that I will be sticking with manual steering. I know I'd have to run a p/s pump, but what would I have to do with the lines that would normally run to and from the p/s gear box?
Any ideas?
Backpayne is offline   Reply With Quote
Old 06-02-2025, 02:31 PM   #2
jayoldschool
Moderator
Re: Hydroboost without power steering?
How about electric boost? Works for EVs.
jayoldschool is offline   Reply With Quote
Old 06-03-2025, 11:18 AM   #3
1964FarmFreshC10
You just run the lines to the hydroboost setup.
many people are running the electric Volvo steering pumps for this exact purpose.
1964FarmFreshC10 is offline   Reply With Quote
Old 06-19-2025, 08:27 PM   #4
cff
Active Member
I had a 66 with a crazy 540 with a tunnel ram in it. I just went to the wrecker and got a vacuum pump out of a 98 cavalier. Worked absolutely perfect and was super easy to install.
cff is offline   Reply With Quote
Old 06-20-2025, 12:14 AM   #5
franken
Connect them to the hydroboost. You probably need a custom pressure line.
franken is offline   Reply With Quote
Old 06-20-2025, 02:12 PM   #6
theastronaut
theastronaut's Avatar
You can use a manual master cylinder with a slightly smaller bore to boost hydraulic pressure a bit. I use a 1" bore MC with the usual squarebody discs and stock rear drums on my '66 and it stops great even when towing. A 7/8" bore would up hydraulic pressure for the same pedal input pressure.
theastronaut is offline   Reply With Quote
Old 06-20-2025, 02:17 PM   #7
theastronaut
Copied from another thread-
Manual pedal ratio is generally around 6:1, power brakes are generally around 4:1. My stock '66 C10 has a 6.25 ratio. The higher the number, the more leverage the pedal has on the master cylinder.
When you convert to power brakes you do two things to take away braking power- reduce the pedal ratio by about 35%, and you generally go from a 1" bore MC to a 1.125" bore MC, reducing output PSI by 20%. The booster is supposed to more than make up for that, right?
With a stock 6.25 pedal ratio and 100 pounds of input force on the pedal you get 625 pounds of force into the MC, which is hydraulically multiplied via the MC's piston surface area of .785 square inch. 625 pounds in turns into 790 PSI at the caliper if you have the typical 1" bore MC.
With a power brake conversion, 100 pounds of force on the pedal gets multiplied by 4 via the pedal ratio for 400 pounds into the pushrod/booster. CPP says a 7" dual diaphragm booster adds 493 pounds of force for 893 pounds of force into the MC. The typical 1.125" MC will turn 893 pounds of input force into the same 893- the bore size has 1 square inch of area so it doesn't multiply the input force any so you have 893 psi at the caliper. This is about 13% more psi than the typical manual setup ** BUT ** this is assuming 23" of manifold vacuum. How many trucks actually make 23" of vacuum? That 13 % advantage quickly fades in the real world.
What happens if we stay with manual brakes but drop down to a smaller master cylinder bore to multiply input force more? With a 15/16" bore you get 905 psi at the caliper, and 7/8" would have 1041 psi. Brake pedal input to output is totally linear and not variable with manifold vacuum, and they work 100% the same with the engine on or off. It's cheaper and easier because pedal modifications aren't needed.
But, everyone says you need power brakes "because they stop better" and brake companies need you to keep believing that so you keep buying their aftermarket "upgrade" parts...
The one benefit to power brakes is that they can have less pedal travel than manual brakes, because of the shorter pedal throw due to the lower ratio, and because the bigger MC bore displaces more fluid for the same amount of travel. Is this an issue in the real world? Its not on my '66 with the stock 6.25 pedal ratio, 1" bore MC, the usual squarebody D52 12" discs in front, and stock rear drums. The pedal drops a normal amount and pedal effort is pretty normal too. If you have air in the lines then you'll have more pedal travel since air is compressible, but you shouldn't have air in the lines if you bleed them correctly. If you have bigger/multi-piston calipers then you'd need to design the whole system around the amount of volume/pressure they need. But for the typical D52 disc setup, a manual 1" bore MC works great and makes plenty of hydraulic pressure without the pedal travel being any more than normal.
