Old 06-02-2025, 06:31 PM   #1
62c30
One piece floor
I ran across a deal on a few one piece floor pans and was wondering if a 63-66 would work in a 60-62? I know the frames are different. So in theory if you put a 63-66 floor in a 60-62 cab it should bolt on to a 63-66 frame?
62c30 is offline   Reply With Quote
Old 06-02-2025, 07:11 PM   #2
bubbasimms
Re: One piece floor
following.....I hope this is true. I have a 62 that could use a floor and and also a frame update.
bubbasimms is offline   Reply With Quote
Old 06-02-2025, 10:51 PM   #3
Getter-Done
Getter-Done's Avatar
Re: One piece floor
Here is an Old thread with Dimensions.
Link: https://67-72chevytrucks.com/vboard/...ame+dimensions
I hope this helps.
The early bird gets the worm,
85 Chevy K-20
Old 06-02-2025, 10:58 PM   #4
62c30
Re: One piece floor
The earlier frames are wider on the front mount but I think the rear cab wall and rockers are the same 60-66. The firewalls besides holes and master cylinder mounts should be close or the same. In theory it should work but all I have here are 60-62 trucks and a floor for a 63-66
