1971 C10 LWB under const.
Any headaches I should anticipate fitting this BB in?
-W/AC will a 3 row aluminum radiator be sufficient or is a 4 row necessary -Motor mount recommendations? -Front spring recommendations for slightly lower than stock ride height? -Fan clearance issues? Any insight/experiences would be much appreciated!
I see getting married as a can't lose situation........... either gonna live happily ever after or get my 1st wife outta the way |
Re: Advice for fitting a '73 454 into a factory SB '71 C10
My experience is not great, BUT,
I have a 68 big block pickup. I bought it in 1980, it still had all it's original stuff (I still have it, although all in pieces). 68 was the first year for a big block. 68-71 uses a specific motor mount and frame bracket, that mine came with. 72 is different. I plan to use the 72 frame bracket and mounts on my 68 396, and may use same on my 67 small block settup (If it worksout, I'm sure it will). If you already have a 3 row rad. I'd try it, to see. It may(?) be enough cooling. Big block and small block fan shrouds ARE different. I just don't know if a one could be modified and used fir the other type of engine. I would also see how the stock springs react to the heavier engine, before you spend $$$... NEXT!!! Last edited by 68Gold/white; 06-04-2025 at 09:22 AM. Reason: bla |
I would step right up and get a 4 row factory copper radiator to start. Has the 454 been rebuilt? What is the compression ratio? Those questions refer back to how much cooling the engine will need.
I'd get the engine installed before making any front spring changes if it was my truck. Less guessing that way. What transmission will you run?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Agreed on the radiator, especially with a 454. Squarebodies came with a bigger radiator for a reason.
**Mild rebuild/ 468 / 4L80E trans... end goal is not having to worry about sitting in summer traffic with windows up and AC on blast
![]() Join Date: Mar 2003
Does the 68 truck have the transmission in it already----never mind I reread. You'll have to move the cross member back for the 4l80 anyways, so you may have to get some drill bits out anyways to relocate. Try to procure some 72 big block stands. You'll need them for the 468. Then there is the early/late water pump pulleys and bracket debacle for the fan and shroud location
Unless you are going to run electric fans, I'd advise getting a BBC fan shroud and have it available when you locate the engine. I don't know why, but the fan on my truck has the clutch about 1/2" from the stock radiator. That puts the engine about 2" forward of where it should be. By all appearances, it came from the assembly plant that way.
With AC definitely electric fans. 100 degree day caught in traffic with a big block and AC on, save money and time by going ahead with fans. The new brushless fans pull very little amperage coming on and require no relays. I'd do a radiator/fan combo of your choice. I had great luck with my Dewitt combo.
![]() Join Date: Feb 2002
I used to run a '67 K/10 Suburban that the PO had shoehorned a 454/TH350/NP205 into. Since there was no engine notation on the SPID, we'll assume it came with the V8 283 as stock. [And SM420/T221].
No attempt at upgrade to the front end springs. That beast's Doghouse would Rock'n'Roll like a miniskirted GoGoGirl in a cage at freeway speeds. Fun truck. I miss it.
Get the 69-71 frame perch"s and motor mounts. They are easier to find and a little cheaper. Make sure to bolt the perch"s useing the most forward holes on the frame rail. You might have to have a drive shaft made for your combination. I have a 540 in my truck and I enjoy the h#%l out of it. You will to.
#11 | |
#12 | |
) Lot's of money on fans, clutches, and water pumps using stock shroud. It cooled great going down the road and for about 15 minutes on a very hot day in stop and go traffic until it started creeping up. Plenty of timing, AFR, and new Dewitt radiator. Added Dewitt's fan kit never ever get's past 185 with a 180 thermostat.
#13 |
#14 |
If you go electric, research a bit about how much total CFM your setup will need, multiply that by a fudge factor to make up for CFM loss due to air flow resistance, something between 1.2 and 1.4 and then purchase either a single or two high quality fans that meet that rating. Fabricate or otherwise acquire a shroud separately. The total amperage draw of your fans must not overstress your charging system as if this occurs, you'll not be getting the CFM you need. Anything less than the above can easily lead to disappointment at the red light on a 100 degree day. YMMV, -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#15 |
When I bought my 68, it had a 454 in it with a TH400. No A/C though. It had a 3 row and it got a bit hot. I am not sure the gauge was 100% accurate though.
As for springs, it had the stock springs from the original 327. No issues at all. It actually sat a bit lower and rode good. |
#16 |
425hp409
![]() Join Date: Oct 2008
I installed a big block in my small block 68 last year. I will be glad to help you with what you need to do to get it installed properly, and correctly. I do have a set of BB engine stands and mounts and a BB fan shroud which I would be glad to sell you. With a stock GM 4 core copper radiator and fan shroud on my truck it runs cool in 100 degree days with the AC on.
Some items that will be needed: 1. Heat shield for the right floorboard 2. new engine stands and mounts, moving engine back 2 inches, necessitating moving transmission back and if using existing transmission shortening driveshaft. 3. recommended installing a heat shield over the starter 4. a good radiator and fan shroud 5. recommended a left valve cover with a slant to clear firewall I can be reached by PM and would be glad to help off line. I also installed factory AC while the engine was out.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Oldsmobile 442, all original Last edited by 425HP409; 06-08-2025 at 03:53 PM. Reason: added line |
#17 | |
Always on the hunt...
![]() https://www.67-72chevytrucks.com/vbo...d.php?t=760308 .
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our payment account info has been changed as of Jan. 2023. Thanks... |
#18 |
More pics...
#19 |
The factory big block is mounted higher and further forward than a small block truck. This is to provide extra clearance at the firewall. Factory big block trucks were high hump floor IME as well because of the increased height and TH400 transmission.
You actually need a LONGER drive shaft when keeping the existing transmission when doing a big block swap. But since you are changing to a longer trans you will need to shorten or most likely get a new driveshaft. I concur with several of the previous posters. Use the 68-71 big block mounts and get a 4 core radiator. The ‘73 would have come with a long water pump, but I am a fan of keeping the short pump setup and the driver side alternator. Replacement brackets can be expensive but the 66-68 Chevelle parts mostly interchange when you are shopping if you can’t find original truck stuff.
#20 |
![]() Join Date: Dec 1999
I am kind of confused here. FWIU there are two mounting points for the engine crossmember. Forward and back. The stock small block trucks all use the forward mount. 4WD uses the rearward mounts as well a some sixes which may use a staggered mount as well. Not making sense to me as some are saying to move engine forward. Thought the BB used the rearward mounts as well. Makes sense to me BB would be in rearward location and lower. Thinking maybe why the BB was never offered in a 4x4. Already in back position and lower engine would reduce axle clearance.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 06-17-2025 at 03:33 AM. |
#21 |
The two wheel drive crossmember only bolts in one place. There are multiple holes for the engine stands on top of the frame. And there are (3) different engine stands. 6 cylinder, small block and big block. You can mount a SBC on the 6 cylinder mounts and it puts the motor in the rearward position ala a 4x4. I would do this if I was converting a 6 cylinder car to a small block. But the big block is too wide to fit in the small block position, much less the 6 cylinder. So the factory big block mounts move the engine up and forward. I don’t recall which hole in the top of the frame the big block uses, but the stands are a different shape and have the large hole in them as you see in Classic Bow ties post.
#22 | |
![]() Join Date: Jun 2005
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#23 |
I think there are 3 sets of holes. What I am not sure about is which ones are needed for big block factory stands.
Your conversion makes no sense to me as the placement of the stands with the 3 different engine combinations moves the trans forward quite a bit each time from the 6 cylinder to SBC then the BBC positions. If you use factory big block stands in factory big block holes they move engine and trans forward relative to a sbc. The location on top of frame is dictated by where bottom of the stand attaches to crossmember. If you put a big block on sbc stands the trans doesnt move.
| Bookmarks |
