Genuine AC Delco HEI Ignition module
Just looking to carry a spare, anyone know if these are the classic real deal or if they're just some foreign make with the brand name?
Oh yea, it's the 4 pin.
Re: Genuine AC Delco HEI Ignition module
I search high and low and found nothing. I did find a "NOS" on ebay, I was skeptical but when i received it looked correct. Just need to be cautious of the seller.
Yea I was checking out Amazon and I know there have been reports of counterfeit items that you have to be leery of and I guess maybe I'm just being overly cautious.
Thank you for the reply. ![]() https://a.co/d/iGNVDsf |
![]() Join Date: Feb 2002
RockAuto is listing an AC Delco Ignition Control Module P/N:....D1906....$42.99.
I used parameters for a '76 C/10 w/292 L6, but they're the same, V8 or L6. I double checked, and got the same P/N and price for a 350.
I like Amazon free overnight shipping and will just include this with some other stuff I'm ordering.
Oh wow, guess I already have a spare or two and one is a GM, the other is a TRANSPO, whoever that is.
Well that just saved me $50. ![]() Once I bought a ACCEL module because I wanted to be the king of the racetrack or something and I heard a faint crack as I installed it. Two months later found me on the side of the road reinstalling the original.
I use Davis Unified Ignition HEI module and keep a spare in the glovebox. MUCH better than stock. I switched between stock and DUI modules on back-to-back road tests and gained very noticeable throttle response and acceleration with the DUI module.
https://performancedistributors.com/...-distributors/
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. Last edited by tim_mc; 06-05-2025 at 07:56 AM. |
Unless the OEM/AC Delco one is from the mid-1970s or older it won't be any better than the random unreliable aftermarket ones. Even good old used ones are pretty reliable.
I looked for one for quite a while and came up with nothing. I tried a Pertronix version which has worked well for 2+ years. I now always keep a spare with me though as I went through 4 of them in about 2-3 years prior. Luckily I bought one with a lifetime warranty, but replacing a bad one with another one that will fail before too long is still a PITA, which is why I tried Pertronix and seem to have landed on a positive solution. I also had trouble finding a quality harness for the module. My original fell apart due to age and the plastic going brittle. I finally found an aftermarket one but the plug housing cracked in half when I plugged it in! They can be hard to find too. I think I ended up with a Proform copy, but again it is somewhat fragile so you need to be careful with it.
1965 Malibu SS L79 Restoration Page 2004 Torrid Red GTO Preservation Page 2006 Brazen Orange GTO Preservation Page Rich Cummings |
#9 | |
Much as I hate to admit it, at my age and beer gut size, along with my SBC sitting in the IL-6 position, I kind of envy the F**d V-8 distributor location. Thanks for the replies guys.
#10 | |
When the HEI was introduced most dealership mechanics were about 5’7” and weight about 165lbs ! Very limber and payed to climb into the engine compartment ! All part of the job description.
71 C-20 07 Magnum RT AWD |
#12 | |
![]() Join Date: Sep 2014
My current new module will be going to the glovebox and the new Davis Unified Module will upgrade the dizzy. metal: Thank God I’m a tall 72 year old with a long reach. ![]() Thanks again
Sam 1972 C10 LWB, Hugger Orange/White 2025 GMC Sierra 1500 Elevation, Sterling Metalic |
#13 | |
Since HEI was released back in '75, technology has improved over the years but the OEM specs of stock modules sold today are likely based on the original GM design, regardless of application & cam. Case in point: GM calls for the same 4-pin ACDelco D1906 module in '74 454 V8 Corvettes and '84 250 Straight-6 C10s, same timing curve, dwell, energy, but completely different engine characteristics. Here's a good read on HEI myths and improvements: https://www.chevyhardcore.com/tech-s...-shortcomings/ Would really like to get your thoughts post-install.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. Last edited by tim_mc; 06-07-2025 at 09:35 AM. |
#14 |
![]() Join Date: Jul 2000
I must be the exception to the rule, because I've probably had 10-12 HEI distributors over the years with modules from GM, Accel, and MSD, and I've never had one fail.
But anyway, I recently bought this spare USA-made GM module from Rock Auto. Could be very old NOS that R/A got from a GM dealer or parts store inventory.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 06-07-2025 at 12:21 PM. |
#15 |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Guilty as charged, but 5' 9-1/2". Of course, getting married and then a desk job destroyed my lean figure.
| Bookmarks |
