Old 01-17-2004, 02:37 AM   #1
Sonic69
Sonic69's Avatar
New Member with a Question
Hello, I am a new member from Northern Missouri. I have been watching the board for about a year now. I have enjoyed every moment of it! I purchased a 69 SWB Stepside about a year ago, and I am getting ready to start working on it. The truck has had some modifications, but the body is in pretty good condition. My first plan is to attack the suspension and get it down to a lower altitude. The last owner hit two deer at the same time, thus the multi-colored front end. That leads me to my question. The front tires do not set into the fenders the same on both sides. If you measure from the edge of the tires to the edge of the fenders horizontally, there about 1.5" difference. Could this be the frame ends bent, or is the cab not mounted correctly, throwing off the front clip? Thanks.
I am looking for 71-72 parts for disc brake conversion if anyone has any in my general area.
69 Chevy Short Step 2wd
Sonic69 is offline   Reply With Quote
Old 01-17-2004, 03:29 AM   #2
elk hunter
may be nothing but an adjustment. does it pull to the side that is back? if this is the case then you have caster issues with the alignment or, if it has a diamond in the frame an alignment shop can tell you. it may not pull with a diamond in the frame. if you are concerned take it in to be aligned they can tell you what is wrong
yeah, but how's it wheel?
elk hunter is offline   Reply With Quote
Old 01-17-2004, 09:59 AM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
If you are going to lower it,you will probably be miles ahead to use the drop spindle kit.Some of the BB members carryy them.It will lower your truck and give you disc using all new parts.In doing it with used parts you may need to replace calipers ,hoses and other parts easily bringing the $$ to more than the kit.Then you would still need to lower it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-17-2004, 10:24 AM   #4
Low69CST
How do the body lines look? Is the door-fender gap same on each side? Does the hood set in it square. I guess it could have knocked the cab crooked, but wouldn't think it wo uld be that much.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 01-17-2004, 11:08 AM   #5
Blue Beard
Blue Beard's Avatar
Check the factory measurements on the gaps too.........
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-17-2004, 12:19 PM   #6
Sonic69
Sonic69's Avatar
The body lines appear to be the same from one side to the other. When you stand in front of it and look down the side, the fenders looks pretty straight compared to the cab. The gaps are close, not perfect but not rubbing or excessive. If just looks like the cab and clip are mounted crooked on the frame. Is that possible? I plan to take it down to the frame and start from the ground up, but I would like to figure out what I need to do so when I put it back together it is right. The truck drives fine, no pulling one way or the other. Thanks.
Old 01-17-2004, 12:23 PM   #7
Gordo
Smile
Welcome to the board from Connecticut!
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 01-17-2004, 12:56 PM   #8
Rod
Welcome to the 67-72boards.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 01-17-2004, 03:16 PM   #9
krue
Designated A-hole!
krue's Avatar
Welcome to the board from South Mississippi!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-17-2004, 03:28 PM   #10
lukecp
Formerly yellow72custom
lukecp's Avatar
Welcome from a fellow Missourian!
I agree....take the truck to an allignment/frame shop to check the condition of the frame. I don't think hitting two deer...even two BIG deer would bend the frame on one of these trucks, but who knows.
You would also have to get an allignment after lowering it and rebuilding the front suspension anyway
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 01-17-2004, 05:00 PM   #11
Leinie
Is it possible that the wheel offset is different from one side to the other ? Not likely, but worth a quick look. Nice looking project !!
Leinie is offline   Reply With Quote
Old 01-17-2004, 05:29 PM   #12
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
Measure corner to corner on the frame (left rear/right front...right rear/ left front). If the frame is pushed back on one side it will measure longer on one mesurement than the other.
Welcome from Texas! Nice truck you got.
"Who owns this car with the peace sign, the mag wheels, and four on the floor?"
67 Short Step
283/TH400/4.11
BtnkBndt is offline   Reply With Quote
Old 01-17-2004, 07:53 PM   #13
nu2-72
Welcome from NW MO.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 01-17-2004, 08:34 PM   #14
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Welcome To The Board From The Great White North!!!
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 01-17-2004, 09:21 PM   #15
Jace's68
Jace's68's Avatar
Welcome from Kentucky.
Jace's68 is offline   Reply With Quote
Old 01-17-2004, 09:43 PM   #16
elk hunter
how is the bed-to-cab gap thats where a diamond in the frame will rear its ugly head! i dont think deer are going to tweek the frame either but thats the story you got from the seller right.....and welcome by the way from another green horn
Old 01-18-2004, 12:17 AM   #17
dinnut
dinnut's Avatar
welcome to the board from houston texas. just check several measurements from side to side and make sure nothing is off and have a good alignment shop check everything out and align it
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 01-18-2004, 01:28 AM   #18
Sonic69
Sonic69's Avatar
Thanks for all the input. I will get the tape measure out and see what I find out, and see what the alignment shop has to say about it. Thanks again.
Old 01-18-2004, 02:40 AM   #19
Rooster's 67
Rooster's 67's Avatar
Sonic69
spend 25+shipping with RICKS and get an assembly manual, it can give you all the measure points to triangulate the frame and mount points to see if it is bent or out of whack. very neat book, and yet so very handy
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
