POR15 into inner roof
Anyone out there considered spraying POR15 into inner roof and windshield area to prevent any rust from forming. Will be going through roof light and visor holes ? I have a small water leak and will pull windshield to replace with new GM seal later. Looks to me like the seam sealer man went a little thin on application.
![]() Join Date: Dec 2009
Re: POR15 into inner roof
I have used a product similar to this in the link below.
It worked great Eastwood has changed the brand they carry. This is a use the whole can type of product. Link: https://www.eastwood.com/kbs-coating...tip-75101.html
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
I did that on my Burban. I sprayed into everyplace I could get the sprayers wand into. I even added some more holes. The link below starts with some information and photos on what I did.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
POR15 is a fantastic product. I ground down my wife's '69 Beaumont floors to bare metal, cleaned up, then coated with POR, before applying sound mat (foil backed tar based, then foam). Great stuff IMHO.
#5 | |
![]() Join Date: Dec 1999
Kind of do not understand. POR15 is a product meant to be applied to rusty metal. There are much better products availble to protect bare metal.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#7 | |
If you replace the windshield gasket make sure you don't get one from Asia. It'll rot away in a year or two. |
I plan on using a product called Wax Oyl, it is a waxy substance that also has rust inhibiting properties that is easily sprayed via a sprayer with a long flexible small diameter tube (about 36 inches) to reach hard to get at areas. I will spray it into the roof area from the visor holes, into the A and B pillars, rockers, etc. I highly recommend it.
![]() Join Date: Feb 2022
May wany to research prevention vs encapsulation vs conversion type products. I would think a 50+ yr old truck is probably to the stage of needing a converter.
| Bookmarks |
