Power Antenna
I would like to convert from the mast antenna to a power antenna. Before I just out and purchase a random one, is there any particular one that is commonly used?
![]() Join Date: Feb 2002
Re: Power Antenna
Things may have changed since I looked into this, but if you intend to mount your AM/FM Antenna in the stock cowl location, the power antenna units I saw were too large for that position.
Wishing you better luck.
Re: Power Antenna
I am adding a 60s power antenna to my truck.i haven't gotten deep into the install yet but 68orangesunshine is correct it can't go in the stock position. MI e will go in the fender close to the original spot. I'll have some fab work but I'm sure I can get it in here nicely. Looking forward to any further info from ppl who have added power antennas. I mocked it up on the driver side first to make sure it could fit.
| Bookmarks |
