Need help on headers
1972 gmc 2wd. I put in a 383 stroker with some Flow Tech Headers #31500 long tube. I needed to heat and pound the Rh side header to get by my starter. The starter i am running is a Proform 66258 high torque starter. Any suggestions on what i can do so i don't need to destroy my header to make this work?
Re: Need help on headers
Are these new headers?
There is no reason that you should be having this issue in this day and age. I would be calling Flow Tech! Every SBC header has to clear a starter. There is no excuse for having to modify the header. I mean they have had 50 years to figure it out.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#3 | |
![]() Join Date: Feb 2022
Aftermarket parts generally are tested to fit stock oem setups. Your starter is not the original design. You can't expect a manufacturer to test fit for every aftermarket part available.
You could probably sneak a Lester #6449s in there, they are fairly small.
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
![]() Join Date: Feb 2021
Just a thought. Have you tried indexing (rotating) the starter to a different position? I have Doug's 371Y low profile full length headers and they don't interfere with my mini starter
![]() Join Date: Jul 2000
From a description of your starter: Offset design results in more clearance between the oil pan and the starter, and can be rotated for additional chassis clearance.
It's unusual for a header tube to hit a mini-starter.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Flowtech is generally garbage.
Hookers fit fine, but the #5 plug is a tough wire fit. Some folks use shorty plugs, I just made one wire with a straight boot. |
Doug Thorley for the win
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, No Snivelers "No Lowballers, I know what I got"
| Bookmarks |
