Old 06-12-2025, 07:25 PM   #1
JQ-72
JQ-72's Avatar
Are 350 V8s 4 bolt mains?
Visiting from the 67-72 side. I know all 69-72 truck 350s were 4 bolt main blocks. Did this carry over to the square bodies? I ended up with a 77 Big10 and can’t see the suffix code due to the metal fuel line and alternator being in the way. Thanks.
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track
72 Cheyenne Super swb. 350/350 A/C, bucket seats
72 Cheyenne swb. Factory 402/400, tilt, posi, A/C
72 Cheyenne Super K-10. 350/4 spd., posi.
72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack
72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior
JQ-72 is offline   Reply With Quote
Old 06-13-2025, 12:33 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Are 350 V8s 4 bolt mains?
Yes they did.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 06-13-2025, 09:04 AM   #3
Willie Makeit
Willie Makeit's Avatar
I can't answer about ALL truck 350's being 4 bolt mains, but NOT all 350's are 4 bolt mains.
Willie Makeit is offline   Reply With Quote
Old 06-13-2025, 11:23 AM   #4
kwmech
No, not all of them were 4 bolt mains. I think GVW had a play in it. I replaced the 350 in my 1-1/4 ton motor home chassis with a big block. 350 I took out had 4 bolt main and a forged STEEL crankshaft. I expected the 4 bolt but not the crankshaft. I've pulled dozens of engines out of these trucks and it was a mix of 2 and 4
Old 06-14-2025, 09:25 AM   #5
Pontiac1976
Ok but most all 4x4 truck 4bolt. But you can get a 2 bolt much cheaper turned into a 4 BOLT that is stronger than the factory true 4 bolt at the mains you should look that up talk to a good shop if you want a factory style 350 strong main caps you want the angle style caps the allow blots to go deeper the block over the true 4bolt factory set up. If that what you're looking into the true 4 bolt factory for. If not save money aftermarket 383 I have seen quite a few factories true 4 bolt tore part down, there not as strong most people hope to think they are.
Old 06-14-2025, 10:07 AM   #6
Getter-Done
Getter-Done's Avatar
On some trucks, I have been able to take just the top Alternator bracket off
and remove the belt then lay the alternator over to the passenger's side
and move the fuel line just enough to see the code.
The early bird gets the worm,
85 Chevy K-20
Old 06-16-2025, 10:19 AM   #7
kwmech
What 'code' is that. Block casting number 3970010 doesn't mean a thing with 2 v 4. Serial number doesn't indicate this either. then there is this thread from over 20 years ago
http://67-72chevytrucks.com/vboard/s...ad.php?p=89226
Old 06-30-2025, 02:48 PM   #8
cag
Active Member
72 2500, two bolt main
cag is online now   Reply With Quote
