84 disk brake axle on a 70 K10
Found a nos military surplus disk brake front axle for my 70 Suburban. Originally the Suburban had non power drums. The previous owner changed it over to power drums which weren't much better than the non power brakes. I was told to look at 84 K5 Blazer parts for the axle and replaced the one caliper that was missing the brake line rubber plug during outside storage. My question is what brake booster and master cylinder to run. Someone told me that the drum brake mc wouldn't work for the disk brakes. Of course the Blazer mc I got won't bolt up to the booster. Has anyone done this swap to a square body disk brake axle in a 70?
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
Junior Member
![]() Join Date: Apr 2025
Re: 84 disk brake axle on a 70 K10
Just install a 70 disc/drum master cylinder or master cylinder/booster combo.
#3 | |
Any idea where to get a brake hose? The calipers use a banjo bolt setup and the drums used flare fittings going into the wheel cylinder. The 84 hoses are way to short.
Ohhh just had the light bulb go off over my head. Maybe extended hoses for a lifted truck will be long enough!
![]() ![]() Join Date: Jul 2003
Use the booster/MC and proportioning valve from a 1971/72 Blazer.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
I would research the bore size of the master cylinder for the military vehicle the axle came out of. It's very possible that application used larger calipers (Like one ton or bigger) than would be found on a normal truck.
Match the bore diameter in the master cylinder you install and you should have good brake performance. In the later GM trucks there are various brake caliper versions not counting what the government may have specified.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
The military Blazer axle is virtually identical to the civilian axle. I find it strange that the master you bought wouldn’t bolt to the drum booster? When I did the disc swap on my C20 with power drums, a power disc master bolted right up. And I have seen no difference between 2x4 and 4x4 brake boosters.
You can buy a complete disc power booster kit, either full size or smaller diameter double diaphragm versions. Don’t see why you can’t use drum booster brackets on the disc booster, but… The aftermarket booster brackets for a 67-72 are not near as nice and beefy as the OEM 71-72 brackets, they do work just fine however. Pick up a disc booster on eBay and a 71-72 1/2 ton 4x4 master from Rock Auto for the cheapest solution.
![]() Join Date: Nov 2018
I believe Earls makes braided brake lines in just about all configurations and lengths
![]() Join Date: Dec 1999
Disks were not available until 71 IIRC, an option in 71 and standard in 72. 1970cst blazer has a good path. Someone mentioned longer brake lines for a lift. Crown performance is a good option for extended brake lines. Had some lines made for my truck which required longer than availble brake hoses. If it is stock height 72 brake lines should work as long as they are mounted in the same postion.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 06-19-2025 at 04:04 AM. |
#10 | |
Junior Member
Yeah, swapping to disk brakes on a '70 with parts from an '84 K5 is a pretty common upgrade. You’re right that the drum brake master cylinder usually won’t work with disks because of the different hydraulic pressures needed. You’ll want a master cylinder designed for front discs and rear drums (if your rear is still drums). For the booster, many people use a later model square body booster that matches the master cylinder you pick.
All about them K’s
![]() Join Date: Jun 2014
Nope well documented that is not possible from the factory. Front disks were standard equipment in 71 and not available before that. End of story. Your trucks had to have been swapped.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
#13 | |
#14 |
Braided lines for a lifted truck worked. Had to get some adapters and make a line for the driver side. The truck had non power drums and was converted to power drums by a po. IÂ’m going to see what happens with the master/booster setup for now.
| Bookmarks |
