Old 06-18-2025, 08:05 AM   #1
prateroad
71 Chevy truck ac cowl flap screw
Anyone out there know the screw thread size for the cowl flap that the L-shaped arm attaches to? Can't find anything is my parts to match.
prateroad is offline   Reply With Quote
Old 06-18-2025, 03:48 PM   #2
Rick Bollinger
Re: 71 Chevy truck ac cowl flap screw
The metal arm that attaches to the vacuum actuator? If that’s what you are talking about the fresh air flap to that arm I believe it is a #10 sheet metal screw about 5/8” long.
Rick Bollinger is offline   Reply With Quote
Old 06-18-2025, 10:21 PM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I do, but I'm not sure what you ask for. Are you talking about the screw in this pipe-rod connect link thing of jig for the vacuum actuator?
If the actuator is what you mean, here's that info. (bolded)
The upper cowl air door vacuum actuator installs as:
1. The oval nylon bushing slips over the air door’s front stem. The bushing’s flange mounts to the cowl’s front with two 5/16" hex flange tap screws. The screw threads are #10 x 1/2”, and the heads are stamped with 4 lines. The bushing is stamped “B”.
2. The upper cowl air door pipe rod slips onto the air door’s stem with their holes aligned. The rod mounts to the stem with one 5/16" hex flange tap screw. The screw threads are #10 x 1/2", and the head is stamped with four lines. Install this screw after the actuator is installed.
3. The upper cowl air door vacuum actuator was mounted to its bracket with 3/8" hex nuts and flat washers for #10 studs. The actuator’s port faces down and forward. Some actuators installed with speed nuts, which was optioned for this rebuild. The actuator is stamped “DELCO Made in USA REMY”.
4. The upper cowl air door vacuum actuator bracket secures to the firewall, located above the heater hoses. The bracket mounts with two 5/16" hex flange tap screws. The screw threads are #10 x 1/2", and the heads are stamped with four lines.
5. The actuator’s stem secures to the pipe rod with a push-on retainer nut installed onto its stud. A 1 MM push-on nut can be expanded to fit. Reference images.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 06-18-2025, 11:35 PM   #4
Rick Bollinger
Thanks Tony, I was going off of memory I just assembled mine a couple months back and was going off memory. I believe he was asking about the #10 screw holding the arm to the post on the fresh air door. You nailed it.
Old 06-19-2025, 07:51 AM   #5
prateroad
Appreciate the info, the screw thread size is what I needed.
Old 06-19-2025, 10:58 AM   #6
prateroad
Well, #10 but what thread count?
Old 06-19-2025, 12:00 PM   #7
71CHEVYSHORTBED402
Nearly all small tap screws on these trucks are coarse thread, if not all.
Old 06-19-2025, 08:38 PM   #8
Rick Bollinger
https://www.grainger.com/product/1MB...7950b63113f85e You don't want or need the slot but like this.
Old 06-20-2025, 08:23 AM   #9
prateroad
Mine's not a sheet metal screw, it has factory tapped threads.
Old 06-20-2025, 03:46 PM   #10
Rick Bollinger
Then you have a one of a kind.
Old 06-24-2025, 06:12 PM   #11
71CHEVYSHORTBED402
You guys are going to make me pull my link screw huh?
Strikes me as course thread. Here's the small hardware I had refinished, formerly black phosphate. Does anyone see a tap screw (sharp pointed tip) with fine threads? Really, I'm curious. I don't claim to be an expert, I think I've had to use that gauge type 1-2 times.
Here's the exact screw, the entire unit (link, nylon bushing, bracket) mount with the same five screws, mine are stamped with 4 lines each. It was a kit in other terms. Doesn't mean there weren't variations. GM often did. For instance my 71 blower installs with #8. Tap screws if I remember right. They were #10 in my former 72 C20. All original hardware.
Old 06-24-2025, 10:31 PM   #12
Rick Bollinger
71 Short That pile of hardware reminded me of the days I spent at my blast cabinet cleaning all the screws I could save. Then the powder coating which was much easier than blasting all of that crap. I bet I have 100 hours doing that stuff.
Old 06-25-2025, 12:41 AM   #13
71CHEVYSHORTBED402
I didn't know I could buy a tumbler. If I ever see another little brush on a Dremel, with the )*(&_( rabid wires coming at me again it's too soon. Paint remover on too many, degreaser, rinse, vinegar concoction for maybe a day, rinse & dry, stainless brushes, wash & dry, baking soda bath, rinse & dry, brass brushes x more than 1000 pieces, I even hit the nuts. I learned to very much dislike it, so tedious, but good results.
Never seen powder coated hardware before, seems people are happy with it. Hmm, I wonder how black ARP bolts are coated? GM hardware is awfully good, but ARP looks like another level.
Old 06-25-2025, 09:37 AM   #14
prateroad
Well, I have 3 flaps and all are machine screw thread, even the one I bought new from Classic Parts.
Old 06-25-2025, 07:29 PM   #15
Rick Bollinger
most of my hardware had some rust and or multiple layers of paint. So I needed some rust protection after bead blasting. It works well but, I feel your pain.
