Old 06-22-2025, 03:33 PM   #1
Android04
Android04's Avatar
Spindle Nut Washer - 1985 C30 HELP :)
Afternoon everyone, looking for a little help with a part number.
I picked up another 1985 C30 2wd, that has drop spindles on the front. I just replaced the rotors and realized the key way washers are MIA. I've done some searching online and most part stores recommend:
Dorman: 618-007
or
Dorman: 618-012
I've purchased both and they are both 7/8" ID but will not fit over the spindle. I've search LMC, Classic Truck sites, Haynes book, and etc. and can't find the part number or what true size I need. Trying to get this truck ready for SETN, hopefully will see some of you guys there.
Any help would be great!
Android04 is offline   Reply With Quote
Old 06-23-2025, 06:36 AM   #2
Android04
Android04's Avatar
Re: Spindle Nut Washer - 1985 C30 HELP :)
Is everyone as stumped as me?
Old 06-23-2025, 08:43 AM   #3
Dead Parrot
If it is close, I would try using a Dremel type tool with some type of grinding/sanding bit and enlarge the ID on the washers. Or some of those diamond coated small files.
While likely a slow process, probably faster then another order/try/fail cycle.
Dead Parrot is offline   Reply With Quote
Old 06-23-2025, 08:47 AM   #4
Android04
Android04's Avatar
I was thinking of doing that as well. If not hits today then that's what I will tackle tonight. Thanks for replying Dead Parrot.
