1971 C10 BBC zbar/pivot ball questions.
I was posting a question about the BBC specific "C" shaped pivot ball bracket that bolts to the block, and a question about the Z-bar used in my application, Its a '71 C10, I am putting a big block and am utilizing a super-10 4 speed. This is the first time Ive ever put a BBC in one of these trucks, but I have had many SBC trucks that I utilized car 4-speeds in. I have always hunted up and used the v8 style z-bar, clutch rod and frame bracket since they were different from the straight 6 units, but I discovered the BBC pivot ball is quite different, I have the following questions.
1. Is the V8 (sbc) Z-bar the same as used on the BBC?
2. Is the V8 (sbc) Clutch rod (from pedal to zbar) the same as used on BBC?
Thanks for any help/input/pics, I've always used the sbc set ups from straigt 6 to V8, but this is a first installing a BBC with a manual trans. I would be interested in the specific parts as well if available. Thank you guys for any help/info/or points in the right direction.
