Old 06-24-2025, 04:26 PM   #1
Orence1
Orence1's Avatar
Radiator Issue
Been a while since I have been on the board. Things have been going well but developed a radiator leak last fall. After several failed attempts to repair with JB Weld it is time for a replacement. The truck is a 1972 C-10 LB. It was originally a small block but now sports a 402 with mild upgrades. One of the things that I am noticing as I am shopping online as that a number of vendors claim that their unit is a direct bolt in. However, when I look at the specs they are not all the same width. The OEM radiator appears to be 33" x 18" x 3". The current OEM is a 4 row. The two I am looking at are 2 rows. I am trying to stay under $300. I am also running dual electric fans. I don't tow now haul anything. Truck is strictly custom. Here are two units that appear to be size comparable to the current radiator. I would appreciate any feedback.
Jegs
https://www.jegs.com/i/JEGS/555/5115...RoCnCwQAvD_BwE
Summit
https://www.summitracing.com/parts/sum-384046
Orence1 is offline   Reply With Quote
Old 06-24-2025, 04:56 PM   #2
weq92f
weq92f's Avatar
Re: Radiator Issue
Have a look here:
https://www.championradiators.com/Ch...r-V8-1967-1972
2 Row: $214.00: 1.75" tubes, 19.25" tall x 33.13" wide x 1.75" thick
3 Row: $264.00: 0.63" tubes, 19.25" tall x 33.13" wide x 2.25" thick
4 Row: $314.00: 0.63" tubes, 19.25" tall x 33.13" wide x 2.75" thick
These have documented support on this board from a few members who have run them.
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 06-26-2025, 11:41 PM   #3
Smitty
Smitty's Avatar
Re: Radiator Issue
Champion stands behind their warranty. Currently have one of their 3 core units in my ‘71. It also has 2 electric fans, only 1 works under ordinary conditions. The second comes on when the a/c is in use. Running a HO 350 with a 700R4. The three core replaces a four core that sprang a leak and was warrented.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 06-27-2025, 12:29 AM   #4
Luke87gt
Luke87gt's Avatar
Re: Radiator Issue
I got a cheap eBay special before I knew that most here seem to go with Champion
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 06-27-2025, 08:04 AM   #5
cj847
cj847's Avatar
Re: Radiator Issue
You may know that the radiator "hold downs" are larger for the 4 row radiator than the 3 row and below. That radiator is physically thicker than standard.
Also, make sure you are not comparing core size vs tank size. The radiator is mounted in saddles top and bottom.
cj847 is offline   Reply With Quote
Old 06-27-2025, 08:49 PM   #6
PbFut
Re: Radiator Issue
A good test after install and before any shroud, hose or tranny line connection is to check for continuity between radiator and support. If you find continuity, you have metal to metal contact somewhere. This will likely result in a rub that will create a leak. Find contact, correct then proceed.
PbFut is offline   Reply With Quote
Old 06-27-2025, 10:49 PM   #7
Luke87gt
Luke87gt's Avatar
Re: Radiator Issue
Great tip
1969 C10 Shortbed
