![]() Join Date: Apr 2000
Which grill cools better
I have a 70 with the center bar grill and was wondering if a 71-72 grill would cool better. It has a BB with AC and the FL heat is just to much. I have been a mechanic all my life and worked on these trucks when they where new. Yes Im an old man. But Im trying to think outside the box. If anyone has some real experience with changing grills I would appreciate it.
Thanks Gary
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
![]() Join Date: Feb 2002
Re: Which grill cools better
It would be an interesting aerodynamic study -- to see which of the three Grille styles flows more CFM from frontal airflow.
I would conjecture 1st Phase [67/68]* and 2nd Phase [69/70] would induce more drag than 3rd Phase [71/72]. Except that piece is plastic, so it's less robust to heavier physical forces. *67 and 68 slso have a sheet metal plane from the bottom of the Radiator Bulkhead to the front. Deleted on Model Year 1969 and later. In the end all three Phases are stopped by the Radiator Bulkhead and Radiator, just behind the Grille. So you have a barrier that causes a buffeting airflow rebound. If resources were no barrier to research, wind tunnel tests might show some data. Realistically, the speeds should not exceed 100 MPH. More likely around 70, which is the road speed I have experienced to get best freeway handling. Faster, and the road vibrations make the fabric want to tear apart. That's on an un-rebuilt truck. A Frame-Up Rebuilt may be a lot tighter. But the New Breed trucks have always had the reputation of having similar aerodynamics to a red brick.
https://undercoverinnovations.com/pr...s-show-panels/
I have these on my truck. Seems to help keep air from going up and over the radiator. Not a grill I know but it might help with your heat issue. |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
You'd have to measure the thickness of the grid strips on a '71-'72 grill and compare to the earlier grill's blockage area. If someone gives me the thickness, I can calculate the area. I'm out of town so won't be able to measure my '70 grill until Sunday at the earliest. I suspect that the difference is small. I had a '71 grill in my truck and got rid of it (it was a butcher job) and I didn't notice any difference in cooling when I went back to a stock grill. My FiL may have in fact put that grill in with the running-hot problem this truck has had in all the time he owned it. I cured it a few years ago.
20' Daredevil (Ret)
![]() Join Date: May 2003
Can't advise as to grill differences. Forgive me but I must ask about your cooling system details. Radiator type & condition, shroud, fan fitment in shroud, sealed system with recovery tank, HD clutch fan in good working order, 7-blade factory-type fan?
![]() Join Date: Mar 2023
I’ll keep it simple.
Yeah, 72 grills are cooler
![]() Join Date: Dec 1999
Kind of curious to me that a former mechanic would go this direction with cooling problems? Thousands of 67-70 trucks built with who knows how many still on the road. Even my 94 Chevy truck has a similar grill opening with the bar in center. If you like the 71-72 grill and want it, go for it. My favorite as well. IMO there will be no cooling difference.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
![]() ![]() Join Date: Jul 2003
Always preferred the 1969-1970 style grille over the 1971-1972. Doubt there is a huge difference in air flow between the two.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
![]() Join Date: Feb 2000
even the bowtie in the middle of the '71-72 grille could be hindering cooling
https://gmauthority.com/blog/gm/gene...rolet-flowtie/ It would be interesting to run a model and do some CFD (computational fluid dynamics) ![]() and see the air flow but with how these trucks are fit together you would probably find more air leaks or air going around/under the radiator than through itBesides the BB and A/C what is the rest of your setup like? Big radiator, fan and shroud?
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
#10 | |
All of these front ends were validated to provide adequate cooling at GVW in Death Valley, even up to Medium Duty use. If the OP is experiencing cooling problems its because of the hardware (radiator, fans, etc), not the front end air flow. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
The other thing is this: the airflow is not intuitive.
We decided one time we were going to use some parking lamp openings for an air inlet. Looked like a nice spot for some "ram" effect. We ran the tests and the made no difference. We couldn't figure it out until we ran them using smoke: the air was going in the outboard edge of the inlet and coming right back out the inboard edge of the inlet. It wasn't even entering the ductwork. You are not going to know anything until you smoke it. K
#12 | |
Found this while looking for something else:
#13 | |
![]() Join Date: Jun 2005
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#14 | |
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#15 |
Thought it was customary to smoke afterwards?!
#16 |
Take your grill out and see if there's a big difference. Might not be your problem.
#17 | |
There's your answer - The simplest one that works. K
#18 |
Tomaaato. Tomattto. Woop
#19 |
Largely depends on what is smoked. \\
Some before, or Some after... ![]() ![]()
#20 |
Try the 2747 HD fan clutch. Almost all fan clutches are designed for emissions era 210-220*F lockup. The 2747 locks up at 180-190.
Does your vacuum advance can match the vacuum characteristics of your engine? This is the most common cause for overheating issues. |
#21 |
The 68 grilles are the worst. Most of the 68 trucks blow up because the grilles are so horrible. Please send all those ugly 68's to me and I'll make sure to dispose of them properly.
#22 | |
![]() Join Date: Apr 2016
| Bookmarks |
