Old 01-17-2004, 03:38 PM   #1
68racer
Yeah baby!
68racer's Avatar
Polyurethane mounts for BB? BB in L6 holes?
I am fitting a 502 in place of a 350. At present the 350 is on the original L6 mounts. I like the engine set back. I have a set of original 67-71 big block mounts. They look like they would fit in the L6 position (rear holes). Will this work? Can I get polyurethane mounts to replace the rubber? Can I use the L6 mounts? Will I have any other problems? I don't mind 'adjusting' the cab to fit the engine.
11.37 @116
68racer is offline   Reply With Quote
Old 01-18-2004, 08:00 AM   #2
68racer
Yeah baby!
68racer's Avatar
c'mon guys, ttt. Figured can't use original BB mounts. Any suggestions? Will stock 6 mounts cope with 500 horsepower?
11.37 @116
Old 01-18-2004, 11:26 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I got the 454 sitting in th rear hole's right now with 350 mount's just for mock-up,so ya it fit's..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-18-2004, 03:48 PM   #4
68racer
Yeah baby!
68racer's Avatar
Thanks French, now I need to figure if the ordinary mounts will cope. Can I fit big block pads on I6 mounts? The big block type look stronger as they have a pad on the underneath as well. Also thought about drilling sideways through the stands and fitting later type poly mounts.
11.37 @116
