Old 06-28-2025, 08:12 PM   #1
Eddie70
Eddie70's Avatar
Rear Drum Differences
There's going to be a lot of questions out of me while I figure out my 70 CST.
I pulled the drums off of the rear in order to be able to move the truck around easier. It has been a LOT of years since I've worked on drum brakes, since my first car anyway. I knew I had to loosen the adjuster in order to get the drums off. The drivers side had a slot in the face of the drum!?! I expected the slot to be in the backing plate. Maybe that is a Ford thing. Anywho, I got the drum off. On the passengers side is where things are different. There is no slot in the face of the drum and no slot in the backing plate. However, I was able to get the drum off. The drum on the passengers side is heavier than on the drivers side. I figure that is because of how worn the drivers side drum is worn.
It appears that there should be a slot in the face of the drum or the rear axle has been changed. What is correct for our truck? The one on the left is the drivers side and very worn, the one on the right was on the passengers side. Thanks for any help.
1970 Corvette
1970 C10 CST
Eddie70 is offline   Reply With Quote
