93-94 S10 t5 swap 64 c10 sm420??
I picked up a pretty good deal hopefully yesterday.. it's a 93 or 94 t5(tag on the tail shaft 1352-216) and brought it home and tore it apart and it looks great inside.. but it has a 26 spline / 21 tooth input shaft and I'm not sure if the ole jeep 10 tooth swap will work.. plus the bolt pattern looks not like the older t5s that I'm used to.. I'm sure someone here has ran into this before.. and yes I know the t5 isn't for drag racing and neither am I..lol just looking for a affordable 5 speed highwayable transmission!
Re: 93-94 S10 t5 swap 64 c10 sm420??
That looks like the ford pattern T5 main case, just like the 4th gen V6 camaro went to. I think you can get an aftermarket blowproof bellhousing that has both the chevy and ford pattern on it. Otherwise I'm not sure if there is enough meat on a stock chevy bell to redrill the ford pattern into it. You might be money ahead to get a more common 3rd gen camaro T5 and swap the S10 tailhousing\shifter onto it.
![]() Join Date: Oct 2009
sharing my T5 project thread in case you find anything helpful in it.
agree with 350tz, that is the Ford bolt pattern. |
| Bookmarks |
