Old 01-17-2004, 07:28 PM   #1
jasonrog
jasonrog's Avatar
Glove box lights
Hi picked one up at my local yard. However, when I close the door, the light stays lit. Has anyone experienced this and have any fixes?
Jason
jasonrog is offline   Reply With Quote
Old 01-17-2004, 07:58 PM   #2
jhow66
jhow66's Avatar
The button is not being in far enough. To check open glove box and push button with finger. If it goes out adjust door to close tighter. If not the light is grounded somewhere.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-17-2004, 08:03 PM   #3
jasonrog
jasonrog's Avatar
The light ructions properly. I have adjusted the door as close as possible. I try adjusting it again. Thanks
Old 01-17-2004, 08:08 PM   #4
jhow66
jhow66's Avatar
Cut a small piece of plastic,hard rubber etc. and glue it to the spot that the button touches on the door to take up the slack.
Old 01-18-2004, 02:12 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The striker on the dash that your glove box latches to needs adjusted.
Loosen the 2 philips headed screws, and push the striker forward. (to the front of the truck. Tighten it back down and see what happens.
You may need to find a happy middle ground between where it is, and all the way forward.
