Old 07-07-2025, 07:39 PM   #1
Brian 72 K20
Junior Member
72 front diff carrier removal
I got the wheel axles out and the two caps off, but it won't budge. Am I missing something. I see YouTube videos for dana 44 jeeps and the carrier should pop out.
Brian 72 K20 is offline   Reply With Quote
Old 07-07-2025, 09:51 PM   #2
jerry moss
Born Psycho
jerry moss's Avatar
Re: 72 front diff carrier removal
it's a tight fit, technically you're supposed to use a case spreader but a pry bar will usually work. the shims are inboard of the bearings instead of outboard on a dana.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 07-08-2025, 02:08 PM   #3
Brian 72 K20
Junior Member
thanks, I'm thinking the axle needs to come off and I'll get a spreader cuz if I got to use a pry bar to get it out, I don't want to think about how I'd get it back in.
