Old 01-17-2004, 08:17 PM   #1
69ride
All Go, No Show
69ride's Avatar
how do you make lowering blocks?
I see lots of questions on what size to use for certain applications, But how do you make them. I'm sure I am capable of making them but i just need a step in the right direction. how do you go about making them.
69ride is offline   Reply With Quote
Old 01-17-2004, 08:27 PM   #2
SCOTI
SCOTI's Avatar
You could use some thick walled (.1875 min) 2" square tubing & drill the required holes for the u-bolts using the shock brackets as your template. Make some sleeves to slip inside the square tubing for extra support. These need to be the correct diameter of the u-bolt shaft & should be an interference fit (cut them a little long & grind them down until you can tap them in place w/a hammer). This will cost you the price of steel + an afternoon of your time. You'll still need some longer u-bolts available from a couple of the board vendors or your local high quality industrial bolt shop.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-17-2004, 10:31 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I always use thick wall square tubing. I box the ends just for aesthetic purposes. The wall thickness doesn't really warrant any additional boxing, but it looks more pro when you do.
Longer U bolts from a spring shop usually cost me 28 per pair. Just take one of your stock u bolts to the spring shop and tell them to make a set like them except 2 inches longer.
Old 01-18-2004, 01:25 AM   #4
69ride
All Go, No Show
69ride's Avatar
thanks man. the pic really helps.
Old 01-18-2004, 04:17 AM   #5
Injected68LS1
Injected68LS1's Avatar
It depends on how much you drop you are going for. If you just want a little drop I would buy some aluminum bar that is wide enough for the pad and has the other dimension the amount of drop you want. Then you cut the bar to the right length and drill the correct size holes in them. I think this would work best for 0-2 inches. Thick wall tubing steel always works good too.
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 01-19-2004, 06:20 AM   #6
1972C10
1972C10's Avatar
Ive got a set that was made from old trailin arms 3" and there for sale lol.
1972C10 is offline   Reply With Quote
Old 01-19-2004, 06:38 PM   #7
dubie
dubie's Avatar
good idea for lowering!! Do you have to remove your rear coils to do this?? or can you just make the block, slip it inot place and bolt it back up? I'm thinking about doing this to my flatbed project and then cutting a coil off my front springs
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 01-19-2004, 06:55 PM   #8
Tx Firefighter
No man, you don't touch the rear coils at all. Just the u bolts.
Old 01-20-2004, 04:54 PM   #9
dubie
dubie's Avatar
Hey Tx, how does your truck ride with blocks and cut springs?? i believe it was you that also cut the front springs wasn't it?? Do you have a pic of the truck with this lowering job done on it?
Old 01-20-2004, 05:00 PM   #10
Tx Firefighter
Dubie, the rear lowering blocks have absolutely zero effect on ride quality. Zero at all.
Front, cutting one coil makes it ride more like a Mustang or Camaro. It takes all of the float out of it. Basically, it rides exactly like a store bought lowering spring does.
My wife scanned two pictures of my old trucks last night.
Both of them had cut springs in the front. Both of them, I drove over 100k miles each without any problems or complaints at all.
That's why I get so mad when someone spouts off some "I heard that cutting springs causes the wheels to fall off" or whatever. Things like that were said by people who sell lowering springs or magazine articles for advertisers that sell lowering springs.
Old 01-20-2004, 05:02 PM   #11
1972C10
1972C10's Avatar
I Cut a coil and a half out of my front springs and bought rear lowering springs i never could loate any u bolts to use them blocks and i found some rear springs for 69 a pair.
Old 01-20-2004, 05:02 PM   #12
dubie
dubie's Avatar
yeah i've heard that you don't wanna cut springs because it affects the integrity of the coil. That's BS!! it only effects it if you heat them or cut them with a torch. I'm cutting mine for sure
Old 01-20-2004, 05:02 PM   #13
Tx Firefighter
This one had cut springs in front and drop spindles for 5 inch total drop. It rode as good as stock.
When I put the 17 inch wheels on it, the ride got harsher though
Old 01-20-2004, 05:03 PM   #14
1972C10
1972C10's Avatar
We cut mine with a chop saw little heat Then when i was done i kinda took the edge off with an angle grindler cause factory springs have a little flat part at the bottom.
Old 01-20-2004, 06:38 PM   #15
dubie
dubie's Avatar
Looks like 69ride and I are gonna do a weekend of lower each others trucks in the coming weeks. We both work at the same shop up here in the great white north. Well, he works here, I just supervise
Old 01-20-2004, 06:55 PM   #16
69ride
All Go, No Show
69ride's Avatar
right you just supervise you just distract me and cause me to mess up so any mistakes i make are your fault.
Old 01-21-2004, 02:04 AM   #17
IoWnZa
Big Block Blazer
Feel the love
I am thinking about Bagging, or just straight lowering the Blazer, but I can't decide what to do, I wanna keep my 32's...
/IoWnZa
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys]
IoWnZa is offline   Reply With Quote
Old 01-25-2004, 10:36 AM   #18
MOTHERTRUCKERS
We stock the longer u bolts for blocks. As far as cutting coils, if done with a cut off wheel and a grinder no problems that I have heard of but heating them is a bad idea.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 01-25-2004, 06:50 PM   #19
1972C10
1972C10's Avatar
Do You have any 3 " inches longer than stock? how much?
Old 01-25-2004, 07:58 PM   #20
MOTHERTRUCKERS
Sorry only stock and 2'longer in our catalog suspension section, if you want 3'longer we can make them next week 38.00 a pair, they are heavy grade 8 with rolled threads, tall nuts and washers.
Old 01-25-2004, 08:04 PM   #21
1972C10
1972C10's Avatar
The 2" longer may work seems the stock ones hang out the bottom a good bit whats the overal measurement from the inside of the top u bolt to the bottom of the threads?
And how much do the 2" go for ..
Im just in the sitiuation where i could do springs for 60
Just lookin over all options
And thanks for the info
Old 01-25-2004, 09:21 PM   #22
MOTHERTRUCKERS
34.00 for 2' longer. What kind / brand of springs are 60.00?
Old 01-25-2004, 09:24 PM   #23
1972C10
1972C10's Avatar
I dont recall what brand they were i got the 4" from aim.
Old 01-26-2004, 12:11 AM   #24
MOTHERTRUCKERS
If I remember correctly they are made overseas and not progressive rate springs. Get a good adjustable track arm and some high quality shocks to make up for the poor quality coils and you might be o k.
Old 01-26-2004, 01:04 AM   #25
1972C10
1972C10's Avatar
Ive been running them awhile so far i havent had any problems i have thought about makin an adjustable track bar but havent got around to it..
They seem to do good and give just right amount of give under accelartion I dont haul anything thin with the truck
They are the same diameter as a set of stock light duty springs.
