to notch or not to notch
Doing some measuring today. Thinking may go lower in rear about 5" drop and close to same ionfront. I know will have rake but can adjust some of it out with coil overs and want some rake. Like the look myself. Not bunch but nioticable.
Question is do I have to c notch frame for 5", Doing some searchs seems 5 is in limit and toss up on c notch. While they are sheap a saw,welder,bridgeport mill all sitting here. Can build one easy since have pictures. Can be bolt in or weld in, Seems weld in has to be stronger. Required, needed, just insurance or wasted till go lower?
Only the stupid know too much to learn something new. |
Re: to notch or not to notch
For 5" I would either step notch or Z the rear of the frame.
A C notch will be pretty close to bottoming out to much for my taste. So while your doing the work. It maybe a good idea to build in future expansion. |
The reason some folks don't do frame changes around 5" is they remove the rear bump stops and are okay with banging the frame, while others run stiff springs with shocks with lots of compression dampening to keep from hitting basically using the tires for suspension.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 07-20-2025 at 01:28 PM. Reason: -2 grammar |
I did a bolt in , then bagged the truck and had to remove it for a step notch. It was preformed for the rails and sucked to install. And I cant stress that part enough.
If I had to do it again I would have gone 8 piece notch and cut it down to the height I wanted. To avoid removing and rewelding the crossmembers. Oh well! Its in, it's ugly, it's solid. Maybe one day I'll cut it out again, lol. |
Doing some measurements today. Looks like with 4 to 4.5" drop I should be ok but little too close to suit. going to do a weld in notch 2" deep with notch and a plate spanning 4" to 6? on each side of notch welded in. Kind of like having 4.5 " x 3" x16" 3/16 channel welded in with a 2" notch. Should be stronger than the bolt in stuff they sell.Plus metal laying here and 4 or 5 hours fab plus installation cost nothing but time. Well some grinding tools, welding gat and filler rod.
will set ride height remeasure and see if think might go lower in future, Because be a ***** to cut out what I have designed.LOL Not to insult but not fan of slammed to ground look just not my thing/
At the body shop.
My 73 was no notch for 20 years. Rarely hot til I ditched the roll pan and put a bumper on it. Then it was tolerable but smacked occasionally
Now I've notched it with under bed step notch. Yet to drive it.
" That didnt make it any newer " " Dont antique the equipment " |
With panel anything over inch above frame would mean cutting floor. Not going that far for a look. So if notch hits at 4" either more spring or backup on drop/
4/5 drop and removed bump stops, I have never bottomed out. Bell tech shocks, front and rear sway bars on 18s.
#9 | |
And a quick flip for a great looking truck! ![]() ![]()
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
| Bookmarks |
