Old 07-15-2025, 06:44 AM   #1
cag
Active Member
long beds with sbc swap, two piece driveshaft angles????
what did yall do about your two piece driveshaft? how were the angles?
cag is offline   Reply With Quote
Old 07-15-2025, 10:07 AM   #2
1964FarmFreshC10
Re: long beds with sbc swap, two piece driveshaft angles????
Angles shouldn't be an issue at all with a 2 piece shaft.
At most you just change the length of the shorter front section which will have no effect on the pinion angle.
1964FarmFreshC10 is offline   Reply With Quote
