Old 07-15-2025, 12:25 PM   #1
Loose Screw
Loose Screw's Avatar
Any Method For Opening Up Spark Plug Wire To Plug Connector?
I have plug wire puller pliers and I do first try to finesse them off by hand first.
But they have been connecting too tight and I have been pulling the connector off the wire and left stuck on the plug pretty tight.
Any Secrets for loosening up the connection a bit before install?
Thanks!
Loose Screw is offline   Reply With Quote
Old 07-15-2025, 08:56 PM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Any Method For Opening Up Spark Plug Wire To Plug Connector?
Silicon dielectric grease on the plug tip before install helps. It they seperate after pulling, you will have to start over -- slip the rubber cover back on the wire [silicon helps] -- cut back the insulation, leaving the lead -- then crimp a new metal connector on, and worm the rubber back into place.
Old 07-17-2025, 09:36 AM   #3
MARKDTN
Yep, once you don't use it and they stick it's too late.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 07-17-2025, 09:49 AM   #4
Orange71shorty
I’ve opened up the ends with the right sized Philips screwdriver, one that a tad bigger than the ends. The shape of the screwdriver makes it easy to spread the end
Orange71shorty is offline   Reply With Quote
Old 07-17-2025, 12:41 PM   #5
Loose Screw
I switch from Duralast to Duralast Gold, did a test before install and they are looser. Yeah, I always try to used sillycone grease on electrics when applicable........
Thanks!
