Old 07-15-2025, 01:11 PM   #1
OldChevy1954
Question My HO72 Questions
I have a 1972 HO72 under my truck. I'm trying to figure out if it's a posi or limited slip or locker or what.
Rear axle on jackstands, transmission in Park, I can rotate rear wheels without the driveshaft turning.
When I turn one side the other wheel turns in the opposite direction.
Never does one wheel stay still when turning the other.
What do I have here?
Thanks!
OldChevy1954 is offline   Reply With Quote
Old 07-15-2025, 01:59 PM   #2
Chaparralman1974
Chaparralman1974's Avatar
Re: My HO72 Questions
If one side is spinning in one direction and the other in the reverse direction, you have an open differential.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20 "The Town Truck"
Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272
Chaparralman1974 is offline   Reply With Quote
Old 07-15-2025, 06:26 PM   #3
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Originally Posted by chaparralman1974 View Post
if one side is spinning in one direction and the other in the reverse direction, you have an open differential.
Clay
x2
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 07-16-2025, 12:36 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Clay
x3
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-16-2025, 09:13 AM   #5
MJN
MJN's Avatar
The code stamped on the top of the cast differential housing will tell you if it was built with a no-spin or open differential. It should be three letters followed by the build date.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 07-16-2025, 11:49 PM   #6
Mike C
Mike C's Avatar
The only option for the HO rear was the maximum traction or Detroit Locker. There were no “Positraction” type limited slips available. So like the other posters said, if you rotate one and the other goes opposite, open diff. Rotate one and other goes same way, locked.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
