Is it safe to store/move TH400 on its pan?
I have a rebuilt TH400 I am finagle-ing into a vehicle and remember being taught not to store engines on their oil pans because their weight might affect the seal and cause an oil leak.
What about with my TH400? It is much heavier than I imagined before buying it and I am finding it rather difficult to move it around even on a wheel dolly, but I can't imagine finding a way to keep it off of its pan----but.....I am gonna hate myself if I cause a leak. Opinions?
![]() Join Date: Dec 1999
Re: Is it safe to store/move TH400 on its pan?
Should be fine. Transmission jacks all lift from the pan. A cheap furniture dolly from HF is fine for moving around. Having a surface to set on that goes to edge of pan would be my only recommendation.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
Agree-no issue.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
Don't store it with the convertor installed. It will egg shape the front seal. That seal is a pia when it starts leaking.
#6 | |
BlahBlahBlah
I had TCI build a Turbo 400 for me over 10 years ago. Never used it, its still in the plastic wrapper. Converter, cooler, fluids still in their boxes in a cabinet. I kept the trans stored in the shipping box for awhile, but that got torn getting bumped in to in my small shop. I bought one of those small Harbor Freight dollies, tossed the shipping box, and the trans has been sitting on the dolly for years happily taking rides around my shop.
#8 | ||
![]() Join Date: Jul 2015
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
![]() Join Date: Jul 2007
You can't build anything to roll a transmission around the garage in or store it on for the price of one of those furniture dollies.
They do sell plastic caps/plugs for the pump end and the tail shaft to store or ship them with. I've had transmissions I ordered from rebuilders come in with them. GM used to ship new transmissions with a cross piece that bolted to the bellhousing that supported the converter.
![]() Join Date: May 2007
or bolt the trans to an engine stand if you have an extra one. Support the tail with a 2x4
LUCKTRUCK
#11 | |
It is for both reasons. Not really a big concern if you're installing everything shortly after the build, but letting a 25+lb converter just hang on the seal and pump bushing for months or years before install will absolutely cause issues. Builders will also ship or provide the TC already installed to reduce the number of issues from incompetent installers. My trans guy has hundreds of stories of people who get a bench rebuild, then later are *****ing about a failed trans. 9 times out of 10, it's one of 3 things: the TC was not installed all the way into the pump, the converter clearance was not checked, and it's too far out of the pump, or the shift linkgage was set up wrong and it's holding the detent between gears, eventually burning up forward gears.
| Bookmarks |
