Old 01-17-2004, 10:15 PM   #1
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
speedometer bouncing
what would cause my speedometer needle to bounce around. it was fine and then the other morning it started bouncing
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 01-17-2004, 10:19 PM   #2
rage'nrat638
rage'nrat638's Avatar
must need lube....pull out the center cable part....lube with lithium grease and slide her back in....from the dash side
rage'nrat638 is offline   Reply With Quote
Old 01-17-2004, 10:23 PM   #3
71chevylongbed
Got Horsepower?
thanks, i'll try that
Old 01-17-2004, 10:29 PM   #4
cdowns
cdowns's Avatar
probably cause it's so darn cold whatever grease is in the cable housing is freezin up move to florida will probably solve the prob lem or clean and lube the cable might help too
