Exploding Power Steering Box!!!
Anyone ever have this happen to them?
Just rebuild my power steering box cause the end cap seal was leaking. Got everything all cleaned and back together. Was bleeding the system, turning lock to lock, and on about the 3rd cycle heard a loud pop and metal clank. Found part of the end cap on the ground with about a quart of brand new power steering fluid. Retaing ring and the rest of the cap is still in the box. I have never seen on of these caps explode like this. Anyone seen this before? Anyone know where I can get a new end cap? Ofcourse we are leaving for Hot August Nights next Saturday so this is not the most opportune time for this to happen. |
Re: Exploding Power Steering Box!!!
Summit racing has brand new not rebuilt steering box’s.
![]() Join Date: Apr 2016
Can you post pictures of where on the power steering box that piece came from?
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Were you "two-blocking" the steering gear? Holding the steering hard on the stops generates serious high pressure, which usually bursts the high side hose first.
I was trying to bleed the steering. Going from lock to lock. I didn't hold it hard at a lock stop or anything. Nothing different then when I originally installed the box 2 years ago.
![]() Join Date: Dec 2009
This thread in the link below a member had a Similar experience.
Link: https://67-72chevytrucks.com/vboard/...+cap+explosion
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Properly bleeding the system does not require the engine to be running, only having the front wheels off the ground.
#9 | |
As for having them off the ground, I can think of two reasons- easier to turn the steering wheel, and not scrubbing flat spots on the tires.
#10 | |
Well, I guess I will bleeding it in the next round with OUT the motor running. Thanks for the heads up. |
#11 | |
Part on the left is a good one I was able to harvest from another box I luckily had laying around. Part on the right is the failed part (obviously) Second picture of where it installs on the steering box (already harvested the cap) |
So got the "new" cap installed and followed Rustypile's advice and bleeding it without the motor running (wheels still off the ground). Lock to lock 10 times, topped off fluid at 5th cycle and again after 10. Then started the engine and did 75% left and 75% right (was gun shy) about 10 times. No issues. Dropped her on the ground and took her for a test drive, works great, no groans, no noises, best of all the cap did blow off again.
Thanks for everyone's advice. Now I need to find another end cap so I can rebuild my spare box and have it ready for a future project. Anyone got one laying around or a junk box they would mind parting with the end cap? |
#13 |
![]() Join Date: Jun 2005
What is the screw in the middle of the broken cap?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#14 |
![]() Join Date: Mar 2003
#15 |
That was my addition. Because I was frustrated with the fact I had to tear the entire box back apart just to replace the cap o-ring I had added it to the cap incase the it leaked again and I had do do the o-ring again. Give me something to grab and pull the cap off with from the outside of the box. It didn't have anything to due with the failure, there are no marks on it or cracks emanating from it. Before I put it back together I made sure the it did not come into contact with the piston.
I think my failure was due to air in the system (I had stupidly started the engine with little to no fluid in the pump reservoir) and going full lock with that air in the system. |
#16 | |
Just jack up the frond end. Fill the pump reservoir and slowly rotate the steering lock to lock several times. Refill the reservoir as needed. Top off after the test drive.. As it was explained to me, under pressure, the fluid becomes aeriated, and pressure spikes develop. Aeriated fluid is the primary cause of humming and howling noises in the beginning. Flat spotting the tires is not the reason for having them off the ground. Eliminating resistance to the components while bleeding is the reason. |
#17 |
>>Cardone is one of those.<<
I had to have the Rack on my C4 Vette rebuilt about 10 years ago. Some of those Racks are extremely rare and the rebuilders do not have cores. They rebuild your rack after verifying that it is rebuildable. NAPA sent my rack back east (Philly maybe) to Cardone. Their instructions were to DO NOT START THE ENGINE. Fill the reservoir and use a hand vacuum pump, sealed on the mouth of the reservoir. After the fluid level drops, refill and vacuum again. It works. I have since used that system on a worm gear box and it works. It doesn't aerate the fluid like other methods. Cardone claimed they could tell if I didn't bleed it properly and wouldn't honor the warranty.
'67 GMC 2500, 292, 4spd, AC |
#18 | |
#19 | |
#20 |
Maybe it was a bias tire issue.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
| Bookmarks |
