Old 07-30-2025, 12:16 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Questions about measuring a wheel's backspacing
I wonder why this fellow is measuring backspacing like this as opposed from the flat surface?
If we we're trying to determine the wheel's offset, would you still measure from that area shown by the tape measure, or would you measure from the flat surface?
Thank you
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-30-2025, 01:23 PM   #2
Sicklajoie
The Niner
Sicklajoie's Avatar
Re: Questions about measuring a wheel's backspacing
Measuring backspacing and offset are 2 completely different things.
When doing backspacing, you measure off the point that is flush against the hub, which in this case is that lip on the wheel.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 07-30-2025, 02:57 PM   #3
HO455
HO455's Avatar
That is where I would measure from to determine backspacing or wheel offset. Think of an aftermarket alloy wheel that has only a flat surface. Both wheels need to be measured from the same reference point for the measurement to be accurate for all wheels.
https://www.efxtires.com/news/how-to...IAI2BTWObZFHL-
RIP Bob Parks.
HO455 is online now   Reply With Quote
Old 07-30-2025, 07:12 PM   #4
71CHEVYSHORTBED402
That's an interesting video because it's a vintage wheel with the lip shown in the OP. Unless he's doing it wrong, he's measuring from the flat surface not the lip, for backspace. I don't know why determining offset would be different, short it's a different thing.
Don't have a hub in front of me, but considering the lips are taller they fit in grooves or there's a gap between the hub and wheel center where the lugs are? Seems to me you'd want both groove/lip contact and contact on the center hub, and if that's the case, measuring from the groove or flat surface produces the same results - just guessing from here.
Only talking a small difference flat surface Vs lip, be nice to know for sure though. The guy who measured that OP came up with a 4.25" backspace for his 15 x 8 GM rally. I came up with 4.375 on the same wheel, measured from the flat surface.
Old 07-30-2025, 08:07 PM   #5
71CHEVYSHORTBED402
Well don't I feel so silly. Here's a wheel hub, I believe the answer is it doesn't matter if you measure from the lip or the flat surface, seems the end result would be the same or close enough. - Unless I'm missing it, which happens, it looks like the inner lip fits into a groove, and the outer surrounds the hub.
Old 07-31-2025, 03:43 AM   #6
Richard
The end of tape measure is sitting on same surface as "flat surface" not in the curve? Do not see the problem. Pretty simple, back space is from inside wheel mounting surface to tire mounting on wheel. Offset is difference from center of wheel (wheel mounting surface) using same inside of tire mounting surface. Where I was confused initially is that higher positive offset equals more back space. There are several online converters availble if the the math is confusing.
Richard
Old 08-01-2025, 09:55 AM   #7
SCOTI
SCOTI's Avatar
You measure from the point of contact on the back of the wheels mating surface. Some wheels are perfectly flat; some aren't.
Measure from the surface-to-surface contact point.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-02-2025, 02:42 AM   #8
mr48chev
mr48chev's Avatar
As people who ask questions on this board tend to have a serious adversion to opening links that we who answer questions take the time to post this is the info from the link that HO455 posted. Back spacing measured with the red arrows in the diagram.
My ongoing truck projects:
Old 08-02-2025, 04:28 AM   #9
Richard
Now see where question the points to with this particular wheel. In picture the raised beads are the wheel mounting surface, what you would measure to. The slightly lower "flat surface" section is most likely just to allow a tension on the lug nuts with this wheel. Not an engineer so I do not think like one.
Richard
Old 08-02-2025, 10:00 AM   #10
SCOTI
SCOTI's Avatar
Exactly.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
