01-17-2004, 10:55 PM | #1 |
It followed me home?
heater ball
the heater in my '83 Jimmy will only blow through the floor vent and I was told that I am missing something on the firewall. this guy tells me that there is some sort of ball thing that mounts where I have pictured and connects to the intake? any ideas? thanks
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
01-17-2004, 11:27 PM | #2 |
Robert Olson Transport
sounds to me like the cable that is suppoused to shift the doors from vent to defrost and floor may be broken or something on a non air conditioned truck ive never seen a ball up there and dont even recall one on an air truck i can honestly say both my non air trucks dont have one ( maybe thats why we call a truck female theyre ball less )
01-17-2004, 11:34 PM | #3 |
where is that cable routed? how about those doors?
01-17-2004, 11:38 PM | #4 |
mine did the same thing a few years ago but it was the trap door hinge. It wasnt much fun to fix either. take the inner glove box out & its behind a panel in the dash...corn
01-18-2004, 12:22 AM | #5 |
Heater ball
The heater ball refered to is a vacuum storage tank that keeps a small amount of vacuum to operate heater door motors.
The tank is black with a single 1/4 inch hose fitting. This tanks gets vacuum from rear of carb or fitting going to trans modulator.... Frank
Chevy stepper 400sb 350 turbo |
01-18-2004, 12:35 AM | #6 |
yeah, there should be a vacuum ball mounted there. Not sure exactly where the lines run though, I know one runs inside just not sure where
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
01-18-2004, 12:39 AM | #7 |
the cables go from the heater switch to the heater box the easiest end to check is the heater switch cause you can take that out just a little and see if it operates right by removing the instrument panel bezel and the heater switch with a couple of screws.
to see if the cables are cracked you can follow the cables underneath to the box and see if they move if you need a heater box or any of that stuff i have the whole assembly the switch two of the three cables and the entire heater box id like to get $35 plus ride but if a fellow board member can use it ill let it go for $20 plus the ride, and im open for trades too
01-18-2004, 12:43 AM | #8 | |
thanks for all the help guys, looks like I'll have some more stuff to do here in the next week
01-18-2004, 07:47 PM | #9 |
Well, if you're talking about the vacuum reservoir ball, the one on my '86 Suburban is mounted to the firewall on the drivers side-- above the wheelwell and to the outside of the master cylinder. It's, say, 5" or so in diameter...
Hope this helps.
Semper Paratus |
