Drive shaft choices
Swapping to 4L80E means driveshacft modification in order. I have bunch stuu laying around. One Piece is 3" two piece out iof 1993 3/4 ton PU.
I can. A: Cut(4") front shaft and weld and balance. U joint to adapt to transmission yoke Probably cheapest B: Use 3" shaft means cutting and welding front, finding u joint to mate to old yoke on rear end Make new carrier mount doing anyway for crossmember. C: buy one piece, costly, on long side for speed and then mating to other parts. Ben3fits A: cheapest probably easiest. B: larger diameter should mean stronger and better at high speeds which I have already done with as is. C: No Carrier and less u joints. Opinions and if would reasoning for it. Another not time pressed thing just preplanning my moves.
Only the stupid know too much to learn something new. Last edited by chris mc bride; 08-03-2025 at 11:56 AM. |
| Bookmarks |
