Old 08-03-2025, 09:16 PM   #1
Hawkynz
Hawkynz's Avatar
Camaro/Firebird Sway Bar on 67-72 Truck
I put a sway bar from a Camaro or Firebird, can't remember. I have had it for about 5 years and just now getting around to putting it on. I grabbed all the mounts with it also. They mount on these trucks well. However, my truck is C-notched so right where I was going to mount it, the brace was in the way of my original plan. The sway bar is 1 1/4 wide on both sides of the frame so most people make a spacer and bolt to the frame. I just used some 1 inch rectangular tubing and used an existing bolt in the notch. I highly recommend this modification. It was instantly noticeable.
Hawkynz is offline   Reply With Quote
Old 08-04-2025, 06:06 AM   #2
mkmc69
mkmc69's Avatar
Re: Camaro/Firebird Sway Bar on 67-72 Truck
Nice install. Looks like it was made for the truck. What year of F body sway bar is that?
mkmc69 is offline   Reply With Quote
Old 08-04-2025, 06:18 AM   #3
Getter-Done
Getter-Done's Avatar
Nice install.
The early bird gets the worm,
85 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 08-04-2025, 06:31 AM   #4
jjzepplin
jjzepplin's Avatar
Yup. We all need to know what year Camaro. Looks simple and clean.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-04-2025, 10:50 AM   #5
Hawkynz
Hawkynz's Avatar
I used parts from a 1996 camaro. I believe the same sway bar was used on 80s up to 2002 cameos and firebirds, mayne more. I was getting the calipers off for my disk brake swap and saw the sway bar and took a chance. I have seen them mounted in various ways, on top of the axle, flipped over and used facing forward off the trailing arms etc.
Old 08-04-2025, 01:02 PM   #6
dagnabbitt
dagnabbitt's Avatar
There were a variety of thicknesses on F body rear swaybars, with the Z28 probably being the thickest. Are you able to tell us what size you have?
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
